Propeller IDE running under Mepis Linux
Maybe this has already been done and is no big deal, but I was amazed that it worked and how easy it was.
I have Mepis 6.5. I installed VirtualBox. I installed Windows XP in the virtual box, and shared the FTDI USB serial port. I downloaded code to the Propeller chip and it just worked!
I keep reading how people want the IDE to run native in Linux and/or on a Mac. Is Wine not an option because of the FTDI drivers? Couldn't someone make a cable that converts RS-232 to TTL, and then plug in somewhere else on the development board?
If you wanted to, you could do some win32 tricks, like redefine the shell, put the app in the startup sequence, map a shared drive, or make ftp shortcuts, etc...
Then just click on the VM, let it boot and your app is running in a window.
