Propeller program - help — Parallax Forums
computer guycomputer guy Posts: 1,113
edited 2007-05-14 06:24 in Propeller 1
Does anyone know how to pass the propeller program a command.
More specificly.
things like this (these are from the scribbler program, it runs the command down below - for BS2).
/NoDebug
/NoPrompt
/Download
Like "Propeller.exe /NoDebug /Download file.spin"
For the basic stamp you can use.
"stampw.exe /NoDebug /Download file.BS2"
but i don't know what to do for the propeller.
    edited 2007-05-13 02:17
    The Propeller Tool is interactive only. I don't believe there is any way to pass information to it. We've been over this before in the context of using the Spin compiler as a back end for a C to Spin translator or a macro pre-processor and have been told that it cannot be done and that we should wait for the eventual release of the compiler as a library like the DLLs for the Stamp. Now that Parallax has said that there will not be a cross platform DLL for the Propeller, it seems likely that there may not be a DLL for Windows either..
  • computer guycomputer guy Posts: 1,113
    edited 2007-05-13 02:19
    Is there any other way to download the code to the propeller from a file using perl.
    Post Edited (computer guy) : 5/13/2007 2:35:17 AM GMT
    edited 2007-05-13 03:06
    There's a loader written in Python (http://forums.parallax.com/showthread.php?p=611536).
    edited 2007-05-13 03:17
    Thanks Mike will look into running that from the perl code i have.
    I am using the scribbler code with a propeller chip.
  • AribaAriba Posts: 2,697
    edited 2007-05-13 05:07
    You can also use PropTerminal for Download - see:
    http://forums.parallax.com/showthread.php?p=649540
    With: PropTerminal.exe filename.binary -L ComNr
    the Terminal will only download the binary file in the RAM of the Propeller chip and terminate then.
    Andy
    edited 2007-05-13 05:11
    Thanks but no thanks.
    I am using spin not binary and i need something that can run in the background(not visible).
    edited 2007-05-13 05:13
    If you are interested though, and you know delphi (or python) and perl.
    You could take a look at the bottom of this post.
    Thank you :-)
    edited 2007-05-13 05:55
    Hello computer guy
    1) If PropTerminal is startet with commandline parameters it does not show the Terminal Window, only a Console Window (DOS Box) that displays the status. In most programming languages this Console can be hided with a parameter in the function that starts external programs.
    2) You can't download a Spin File directly, it must be compiled first, and this can do only the Propeller Tool IDE until now. But you can save the compiled version of a Spin File as .binary and download it with this Phyton- or delphi code, or with PropTerminal.
    Andy
    edited 2007-05-13 06:03
    Would still like something built into the program.
    edited 2007-05-13 06:35
    @computer guy
    OK, because of the same reason I included a loader in PropTerminal.
    @Mike Green
    Mike Green said...
    The Propeller Tool is interactive only. I don't believe there is any way to pass information to it. We've been over this before in the context of using the Spin compiler as a back end for a C to Spin translator or a macro pre-processor and have been told that it cannot be done...
    Perhaps it will be possible to 'remote control' the Propeller Tool with Send-Keys messages from another Application. Every Application in Windows can send messages to another window. But there will be no feedback from Propeller Tool, so the controling application has to wait a fixed time after a command, that is long enough also for slow computers.
    Just an idee...
    Andy
    Post Edited (Ariba) : 5/13/2007 6:42:19 AM GMT
    edited 2007-05-13 11:56
    Is there a way to detect which com port the prop is connected to.
    edited 2007-05-13 14:17
    You have to open the port (to reset the Prop) and successfully go through a dialog with the Prop (essentially do an "identify chip" sequence). This can be inferred from Chip's loader written in Spin: http://forums.parallax.com/showthread.php?p=591445. The Prop and PC exchange bits from a "linear feedback shift register", then the Prop sends its version number and the PC sends back a command. For "identify chip", this would just be a "shutdown" command.
    edited 2007-05-13 21:52
    Thank you Chip's code has helped me understand it a lot better.
    Will have a go at programming something in perl when i get home.
    edited 2007-05-13 22:03
    What would i do for the RESn pin.
    edited 2007-05-14 02:49
    I'm not clear why you're asking about the RESn pin. Chip's loader takes care of toggling it.
    If you're asking because you're rewriting the routine in perl, consider that the normal PropPlug
    (or equivalent wiring) uses DTR such that the Propeller gets reset when the serial port gets
    opened or closed. Look at the Python version. I think you'll find that the port is opened, then
    the next code is what follows the RESn toggle in Chip's loader.
    Yes i am writing perl code to do it.
    I am 2 days new to perl so may need some help if anyone can supply it.
