Need to increase the AMP
Hi I am new to electronics please can someone help me. I am sending a 5 volt signal out of one of my pins but I think it needs more AMP's can someone tell me what compont I can use for this and how do I do the calculation for the component I need.
Thanks for your help I am new to this
Thanks Cameron.
Thanks Cameron.
Heres a link describing the use of a transistor as a current amplifier with an inductive load, its well worded and worth keeping in your documents folder for future use, even if it does not suit your present needs.
http://forums.parallax.com/attachment.php?attachmentid=37701
Jeff T.
This is some more information about the circuit.
When I test the VSS with no component attached the AMP is about 1130 something like that but when I connect my component it drops to about 85 AMPS. So I think this is too much of a requirement for one of the chips pins however it is 5 volts. So what type of transistor do you recommend. I hope I got the reading right it is on 200 mA on the multimeter.
Thanks for your help with this I am new with electronics.
Cameron.
In fact using the current range of any meter requires a greater level of caution than other functions.
What is the·component you are wanting to connect to the output pin and what is its voltage and current rated at ?
Jeff T
Thanks for the help I really want to get into electronics but I am finding it hard. Okay this is a long story but here it goes. I work for a company that makes bill counters so I got the basic bill counter that they have and I want to copy there main board which i thought seemed pretty easy ( i know someone who knows not very much about electronics but I would love to do this project). This is how it works, the are two motors inside the machine one is a big AC motor and another one is a small DC motor. The main board sends a 5 volt signal to the power board to power the main motor and the small motor. I have measured both connectors and they are both 5 volts well a little bit below 5 volts like 4.8 something like that. So i connected my chip to the small motor cable and to the ground. Set the port as output and sent 5 volts and great the small motor started to turn as it should do. Then I connected the chip output pin to the Main Motor connector and it doesn't do anything. But when I connect the VSS to the main motor connector it starts to spin. So someone told me that it might be because of the AMP. Truth be told I did this with the SX28 micro controller however I do have a basic stamp 2. Any thoughts?
Thanks again for your help
Cameron
Jeff T.
I will see if on Monday I can get the service manuals for you to have a look at if you have the time. Please tell me how to most micro controllers interface with other components because I was under the impression that they simply send out a 5volt to the component like a sensor for example or something like that and if the component required less voltage you would use resistors how do they do this in reality. Again thank you for your time I am new at this. Got any suggestion of things I could read to help me understand these things better.
Thanks Cameron.
http://www.parallax.com/detail.asp?product_id=28123
The resources of these forums are phenomenal, keep reading and doing the experiments in the books and apart from learning you'll probably have a lot of fun too. If ever you get stuck there are plenty of people to help. Of course providing all the relevant information pertaining to your question is most important.
Take care
Jeff T.
Cameron.
Though written with the Stamp in mind, the information presented is applicable to SX.
Cameron
use part of this circuit,· you will need a 220oh resistor, one mosfet and one diode, all from your local radio shack
Fernando Gomez
revinc.us
gomez-rivera.com
Never compare yourself with anyone else, there will always be someone bigger·or·smaller·than you.
