Using the Parallax Ultrasonic Sensor to measure liquids (Need to add protectio
Only to know how can I cover the Parallax Ultrasonic Sensor.
I need to measure water inside a tank.
It is very important to protect the ultrasonic sensor
from the water.
The water is quiet but some littles drop could splash
the sensor.
I think that the electronics could be cover and the transmitter
and receiver could be without cover but I think that the
transmitter and receiver will receive some drops of water.
Do you know how can I protect this sensor ?
and
Do you know where can I buy the same sensor with cover?
Thanks, Joe
from the water.
the sensor.
and
Thanks, Joe
The only thing I can suggest is we did some testing by sealing the PING))) behind a panel using silicone (which was, by the way, holding the PING in place) and it didn’t affect the operation at all. Given that if some liquid hits the transducers it may not cause any permanent harm, especially if it’s just water. The transducers should almost dry themselves especially with the ultrasonic effect of the 40 kHz continuous pulse. We haven’t tried this but it stands to reason. Covering the PING))) just isn’t an option because that would affect the transducers and impact the range. I hope this helps. Take care.
Tracy Allen
www.emesystems.com
- Stephen
It seems that Tracy Allen idea is ok.
But do you know if can I replace the two transducers ( transducers only)
by the http://www.futurlec.com/Ultrasonic_Sensors.shtml transducers ?
At the end of that web page there are sealed transducers . My problem
is to know if I can replace them (same volts and freq.) or if I need a new circuit.
If a need a neew circuit, do you know where can I find a good one
becuase sometimes the circuits I found using Google are not goods.
Thanks, Joe
PS: Of course, always using Basic Stamps.
I have the one Ping module from Parallax and I replaced the two ultrasonic
sensors.
Then I bought the Waterproof Ultrasonic Sensor from Futurlec
( http://www.futurlec.com/Ultrasonic_Sensors.shtml )
But the Ping with the new sensors send erratic numbers.
Ultrasonic sensors from Futurlec are 40Khz too, and
I don't understand where is the problem.
could you help me please , Thanks, Joe
http://www.controlcomponents.com.au/products/product_results.asp?PRODUCTS_TYPE_ID=20
http://www.ferret.com.au/articles/z1/view.asp?id=124250
