Just the right battery
As a programmer that is trying to transition into Robotics, my mind gets fuzzy when it comes to battery power for my circuit. If a motor needs 12V of power what's the difference between a 12V/700mAh battery and a 12V/1300mAh battery? Would the 1300mAh battery potentially fry my components?
Please excuse my ignorance.
Practical outcome being -- the only difference between a 12V/1300mAh battery and the other is that the 1300 mAh battery will run almost twice as long as the other one. It's got twice the 'juice', but at the same 'pressure', so it takes twice as long for your circuit to use up the 'juice' -- a good thing.
So no, it won't 'fry' your components. Too much voltage MIGHT cause too much current to run, but 12 volts is not "too much voltage" for the BS2.
When choosing batteries it's also a good idea to consider how each type of battery likes being treated, and match that to the application at hand.
Good Luck,
Marty
