MAX232 question
LearnerNM
Hello: I'm curious about the serial port adapter on the BOE board. Does it have a MAX232 chip? If not, is the MAX232 an adapter I will need to use instead of the port adapter on the board? Thanks.
You can use the DB9 port for debugging and data as long as your application can tolerate a reset every time the serial port is opened/closed. If you want an RS232 connection to other I/O pins, you can either use a MAX232 or you can probably get by with a resistor or two as shown in the PBasic manual in the section on the SEROUT and SERIN statements.
You may also need a MAX232 on the I/O pins if the device you’re trying to communicate with requires handshaking signals since these are not available on the BOE programming port. Some devices also require RS-232 levels rather than the inverted TTL signals from that port when talking to DCE equipment. Take care.
