Program Doesn't run stand alone on dev board
Using professional development board, with sx key,to program SX, program works well with SX key attached, when I try to run standalone, it doesn't seem to run.
I had a break from this programming so I would imagine a fairly straight forward fix.
Using Pulse gen on Development board for input frequency to count, displays freq on LCD
thanks
nige
' Reads a frequency and countspulses then converts to display on serial backlit LCD
' Device Settings
DEVICE SX28, OSCXT2, TURBO, STACKX, OPTIONX
FREQ 4_000_000
ID "SEROUT"
' IO Pins
PotPin VAR RA.0 ' I/O pin for RCTIME
Sout VAR RA.1 ' output to 2x16
freqin VAR RA.3 ' frequency input
' Constants
Baud CON "N9600"
LcdI CON $FE ' instruction
LcdCls CON $01 ' clear the LCD
LcdHome CON $02 ' move cursor home
LcdCrsrL CON $10 ' move cursor left
LcdCrsrR CON $14 ' move cursor right
LcdDispL CON $18 ' shift chars left
LcdDispR CON $1C ' shift chars right
LcdDDRam CON $80 ' Display Data RAM control
LcdCGRam CON $40 ' Character Generator RAM
LcdLine1 CON $80 ' DDRAM address of line 1
LcdLine2 CON $C0 ' DDRAM address of line 2
duration CON 900 ' sample count duration
Backlite CON $FD ' back lite command
' Variables
analog VAR word '
anathou var word
anahun var word
anaten var word
anaone var word
anacalc var word
char VAR Byte ' character to send
idx VAR Byte ' loop counter lcd buffe
idxs VAR Byte ' loop counter speed
line1 VAR Byte(16) ' line 1 buffer
line2 VAR Byte(16) ' line 2 buffer
spd VAR Byte(4) ' speed array
thou VAR spd(0) ' thou
hund VAR spd(1) ' hund
tens VAR spd(2) ' tens
units VAR spd(3) ' units
tmpB1 VAR byte ' subroutine work vars
tmpB2 VAR Byte
tmpW1 VAR Word
PROGRAM Start
' Subroutine DECLARATIONS
TX_BYTE SUB 1, 2 ' transmit a byte
DELAY_US SUB 1, 2 ' delay in microseconds
DELAY SUB 1, 2 ' delay in milliseconds
UPDATE_L1 SUB 0 ' update line 1 of LCD
UPDATE_L2 SUB 0 ' update line 2 of LCD
UPDATE_LCD SUB 0 ' update both lines
' Program Code
Start:
DELAY 750 ' let LCD initialize
TX_BYTE LcdI ' clear screen, home cursor
TX_BYTE LcdCls
pause 50
TX_BYTE Backlite ' back light on
DELAY 1
put line1, "RPM: " ' initialize LCD buffer
PUT line2, " "
Main:
count freqin,duration,analog ' read freq (10 us units)
anathou = analog / 1000 ' freq in / 1000 if > 1000 then 1000's will be in anathou LSB
anahun =__wremainder ' anahundred word contains remainder
thou=anathou_lsb ' convert to single byte for use in TXBYTE
anahun= anahun/100 ' anahund / 100 if > 100 then will be in anahun LSB
anaten=__wremainder
hund=anahun_lsb
anaten = anaten/10
anaone=__wremainder
tens=anaten_lsb
units=anaone_lsb
thou = thou + "0" ' convert 1000s to ASCII
PUT line1(6), thou ' move to LCD buffer, in position 6
hund = hund + "0" ' convert 100s to ASCII
PUT line1(7), hund ' move to LCD buffer in position 7
tens = tens + "0" ' convert 10s to ASCII
PUT line1(8), tens ' move to LCD buffer
units = units + "0" ' convert 1s to ASCII
PUT line1(9), units ' move to LCD buffer
UPDATE_L1 ' update LCD
UPDATE_L2
GOTO Main ' do it over
' Subroutines Code
' Use: TX_BYTE theByte {, repeats }
' -- first parameter is byte to transmit
' -- second (optional) parameter is number of times to send
TX_BYTE:
tmpB1 = __PARAM1 ' char to send
IF __PARAMCNT = 1 THEN ' if no repeats specified
tmpB2 = 1 ' - set to 1
ELSE
tmpB2 = __PARAM2 ' - save repeats
ENDIF
DO WHILE tmpB2 > 0
SEROUT Sout, Baud, tmpB1 ' send the character
DEC tmpB2
LOOP
RETURN
' Use: DELAY_US us
' -- 'us' is delay in microseconds, 1 - 65535
DELAY_US:
tmpW1 = __PARAM1 ' save byte value
ELSE
tmpW1 = __WPARAM12 ' save word value
ENDIF
PAUSEUS tmpW1
RETURN
' Use: DELAY ms
' -- 'ms' is delay in milliseconds, 1 - 65535
DELAY:
ELSE
ENDIF
PAUSE tmpW1
RETURN
' Transfers line 1 buffer to LCD
' -- makes no change in LCD screen position
UPDATE_L1:
TX_BYTE LcdI ' cursor to line 1, col 0
TX_BYTE LcdLine1
DELAY 1
FOR idx = 0 TO 15
TX_BYTE line1(idx) ' transfer buffer
NEXT
RETURN
' Transfers line 2 buffer to LCD
UPDATE_L2:
TX_BYTE LcdI ' cursor to line 2, col 0
TX_BYTE LcdLine2
DELAY 1
FOR idx = 0 TO 15
TX_BYTE line2(idx) ' transfer buffer
NEXT
RETURN
' Updates the LCD with both line buffers
UPDATE_LCD:
TX_BYTE LcdI
TX_BYTE LcdHome
DELAY 1
UPDATE_L1
UPDATE_L2
RETURN
thanks
nige
' Device Settings
FREQ 4_000_000
ID "SEROUT"
' IO Pins
' Constants
Baud CON "N9600"
' Variables
analog VAR word '
anathou var word
anahun var word
anaten var word
anaone var word
anacalc var word
tmpB2 VAR Byte
tmpW1 VAR Word
PROGRAM Start
' Program Code
Start:
TX_BYTE LcdCls
pause 50
DELAY 1
PUT line2, " "
Main:
anaten=__wremainder
hund=anahun_lsb
anaten = anaten/10
anaone=__wremainder
tens=anaten_lsb
units=anaone_lsb
UPDATE_L2
' Subroutines Code
TX_BYTE:
ELSE
ENDIF
DO WHILE tmpB2 > 0
DEC tmpB2
LOOP
RETURN
' Use: DELAY_US us
DELAY_US:
ELSE
ENDIF
PAUSEUS tmpW1
RETURN
' Use: DELAY ms
DELAY:
ELSE
ENDIF
PAUSE tmpW1
RETURN
UPDATE_L1:
TX_BYTE LcdLine1
DELAY 1
FOR idx = 0 TO 15
NEXT
RETURN
UPDATE_L2:
TX_BYTE LcdLine2
DELAY 1
FOR idx = 0 TO 15
NEXT
RETURN
UPDATE_LCD:
TX_BYTE LcdI
TX_BYTE LcdHome
DELAY 1
UPDATE_L1
UPDATE_L2
RETURN
Then tried witha resonator in socket and after power cycled o.k.
Seems to operate the backlite on first cycle of power switch, but no RPM(freq display), then on second cycle of power works fine display reads RPM freq o.k, change freq changes display, any lines of code that standout that would cause that?
I some how thought it could operate on an internal resonator, so looks like thats where I made an error.
looks o.k
nige
nige
If you want to use the internal oscillator change the “OSCXT2” entry in the DEVICE line to “OSC4MHZ”. Be aware that the internal oscillator will not be as accurate as an external resonator.
- Sparks
o.k thanks for the info on oscillator
