Simple Capacitor question
Hi All,
This is pretty embarassing asking this as its pretty simple electronics
In the attached circuit for the voltage regulators on my device, I have a big cap in there (C14) to keep the power to the 5V and 3.3V regulators stable when large currents are discharged through the 9V output.
Do I need to put a resistor in series with the capacitor C14? Or is ok to leave the resistor out?
I need to keep the circuit powered for as long as pos. if the power source drops below Vmin for the regulators.
Thanks!
Thanks!
Did you forget to attach the circuit ?
Regards.
Alberto.
I most certainly did lol here it is. Been a long day!
This is a 12mm dia surface mount capacitor, not sure what you mean by supercap
The issue I have is it needs to be SMD and the largest footprint I can fit on my board is for a Sanyo E12 (which I assume means 12mm dia).
4700uf would hold the circuit up for ~2 seconds which is enough.
Post Edited (Basil) : 5/10/2007 2:35:50 AM GMT
Thanks Mike
I have an idea!
I could change the power supplies from parallel to serial configuration (Ie 9V->Diode->5V->3.3V) and put the cap on the 5V line. That way I can get away with using a lower voltage rated cap. which would allow me to increase its capacitance while keeping the space requirements to a minimum [noparse]:)[/noparse]
Is there any downside to doing it this way? In an earlier thread of mine I asked this same question.
The power loss at the 3.3V regulator would not be so big either.
At first I went with parallel as I thought noise on the power supply lines could be a problem, but in reality the parts I am using do not produce much noise anyway and there are quite a number of smoothing caps [noparse]:)[/noparse]
