Basic stamp Editor 2.2 hangs when sending data from the 'basic stamp 2 / usb' t — Parallax Forums
imported_Daniimported_Dani Posts: 22
edited 2007-05-14 19:31 in BASIC Stamp
I've tried this on diferent PC's and got the same result with the Basic Stamp 2, USB version.
It seems that capturing a stream of·data from the BS2/USB into the BS-Editor v2.2 hangs up the editor so that you are forced to kill the hung application. Is there anyone out there with the same problems?
1280 x 1024 - 132K
  • ForrestForrest Posts: 1,341
    edited 2007-05-09 10:41
    I'd try updating to the latest Basic Stamp Editor 2.2.6 here www.parallax.com/html_pages/downloads/software/software_basic_stamp.asp
  • imported_Daniimported_Dani Posts: 22
    edited 2007-05-09 11:19
    Tried that sir!
    but still the same problem I regret to say.
    The problem now evolved to version 2.2.6 of the Basic Stamp Editor also...
    Thanks anyway
  • Skywalker49Skywalker49 Posts: 172
    edited 2007-05-09 13:08
    Daniel,
    do you mean that if you run a BS2 program while in DEBUG mode, the application hangs ?
    regards, Ed
    edited 2007-05-09 14:30
    Sky,
    not every time, more intermittent-like.
    Every time data is sent to the debug window and sometimes it causes the BS2 editor to crash...
    edited 2007-05-09 14:43
    Daniel,
    Is this on a laptop or desktop PC? Which USB Driver are you using? What are the latency settings in the Advanced Port Properties?
    edited 2007-05-09 17:25
    At the moment I use a desktop PC,
    Latency Timer is 16ms
    Device Manager:
    -Ports
    USB Serial Port (COM3)
    Driver Provider :FTDI
    Driver Date :19-05-2006
    Driver Version :2.0.0.0
    -Universal Serial Bus Controllers
    USB Serial Converter
    edited 2007-05-09 19:11
    What operating system and specifications? All I can think of is perhaps maybe the system is bogged down for process time refreshing the debug window…Everything else looks okay.
    edited 2007-05-09 20:14
    ·Daniel
    One thing that happen to me·on my laptop is that if·Serial cable plug that
    gose to the USB to Serial adapter dose not have good concetion then it will
    hang up and i will have to restart the computer
    I have 4 of these adapters and every one of them dose the same thing
    One other thing if close Basic Stamp·online·help·and open too many time it cause it to hang up as well
    Or if go to the Internet and to the Basic Stamp Editer too many time it will cause
    it hang up as well
    This is on Windows XP
    I do not know if this will help you or not
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    edited 2007-05-09 20:36
    Chris,
    I'm running Xp Sp2 on a P4 3.2GHz with 896Mb Ram idle round 1 or 2 %. No problem with performance it's actually sleeping...
    edited 2007-05-09 20:44
    Sam,
    I use the USB version of the BS2. See the attached file.
    and have a problem with the debug window in the editor when data is sent from the BS2 to the console (debug window)
    Thanks anyway..
    640 x 480 - 53K
    edited 2007-05-09 21:38
    Dani
    edited 2007-05-09 23:10
    Phil,
    I'll try that and report back here.
    edited 2007-05-09 23:15
    Phil,
    that did'nt work either I'm sorry to say.
    edited 2007-05-14 12:28
    It seems that if it is a shared comport (mouse com1 and bs2 on com3 (shadow of com1)) the problem exists. If on the other hand com 4 is used (mouse on com1 and bs2 on com4 (shadow of com2) the problem seems to disappear. Maybe something to think about for those that have the same problem.
    Thanks people for your input..,
    Dani
    edited 2007-05-14 14:48
    Daniel,
    I’m not sure the two are related. What you refer to applies to hardware UART devices which, on older computer used to share IRQ 3/4 for COM1/3 and COM 2/4. The USB controller will (should) have its own IRQ and shouldn’t share with any hardware COM ports. Take care.
    edited 2007-05-14 14:52
    Ok, so what is the answer than?
  • Jeff MartinJeff Martin Posts: 762
    Hi Dani
