Etching circuit boards
Hey everyone,
I am trying to etch my own circuit board. I purchased a copper clad board at R-Shack as well as a bottle of the solution. I drew out my schematic using a sharpie marker and went over it 3 or 4 times till it was very dark. I then submerged it in a plastic tub with the solution. I also have it encased in a water jacket full of boiling hot water.
How do i remove the last bits of copper that are still left on the board?
Pat
Pat
- Stephen
When we etched it at room temp it would take 20-30 minutes (not a lot of options to heat the etchant in my lab). Sometimes there would be some spots of copper we could not get to dissolve. The methods we used were some fine grit sandpaper, the corner of a scotchbright pad. You shouldn't need to remove ALL of the copper, just enough to isolate your traces. Some PCB design software allows you to place copper pours so you only etch what is needed to isolate traces, not remove everything but the traces.
The software that we used with those Press-n-Peel transfer pages was Dip-Trace. The free version allows up to 125 pins, does schematic capture and PCB layout from schematic.
Hope this is helpful, we worked with this and on this from Sept. 06 to Feb. 07 -- He did place 1st in state for the project after all that.
Sal Lorenzen
www.techedguy.com
Craig
I would love to change the world, but they won't give me the source code
People say that if you play Microsoft CD's backwards, you hear satanic things, but that's nothing, because if you play them forwards, they install Windows.
I spent a minute looking at my own code by accident. I was thinking "What the heck is this guy doing?"
I've haven't experienced this problem on any of the 5 boards I built from Radio Shack copper clad. There's an industry standard specification for the copper peel strength. So unless Radio Shack is selling rejected material - this shouldn't happen.
