DC motor driver burning
Hi!!
I wanted to connect a DC motor to a driver ( L6205N ) and after having much fun seeing how it burns I would like to try how the motors work ...
The DC motor needs a 12 V supply and I am connecting it to the driver which is powered also a 12 V (I thought this power should be enough because it is required a Charge pump circuit to obtain more voltage)
Anyway, I couldn´t see if this voltage was enough or not because the driver burned !!
I didn´t connect it wrong or anything of the style ... [noparse]:)[/noparse]
here, some specs: L6205N ; DMOS Dual Full Bridge·, ·max 2,8 A DC;· supply voltage from 8 to 52 V
and the DC motor has a rated current of 530 mA
Had anyone ever this problem???
Thanks a lot!! my next L6205N will be thankful too!
PS: I attach u some specs, just in case
fang-wei
fang-wei
Craig
I would love to change the world, but they won't give me the source code
People say that if you play Microsoft CD's backwards, you hear satanic things, but that's nothing, because if you play them forwards, they install Windows.
I spent a minute looking at my own code by accident. I was thinking "What the heck is this guy doing?"
