I am looking to interface and gas and water sensor to my BS2.
Hello,
I am looking to interface and gas and water sensor to my BS2. Has anyone tried to interface such sensors? Any recommendations as to a what sensors might work with the BS2?
Waveman
Post Edited By Moderator (Chris Savage (Parallax)) : 5/8/2007 3:04:16 AM GMT
Waveman
You need to be a bit more specific as to what you want to measure.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
W
You may be able to rig something up from this. Using a voltage regulator that has a thermal shutdown feature can be used to detect very slight temperature variations in flowing air by monitoring the voltage output at the critical point of shutdown temperature as the voltage varies or moves exponentially in this area similar to a fets turn on/off point.
http://www.flowmeters.com/products/index.cfm?task=pgDetail&pgID=529
This is a good read on water pressure sensors. A strain gauge on a rubber tube can be used to measure water pressure. There is information on this site on strain gauges you can search for.
http://www.omega.com/literature/transactions/volume3/pressure.html
Waveman
