The new Spin Stamp
Any news of the availability of this chip?
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
The Spin Stamp already has the TTL to RS232 adapter built-in just like the other Stamps so I'm not sure you can use the Prop Plug with pins 1-3. The Propeller programming is done using a Prop Clip applied to a set of pads on the end of the substrate. If you want to use a Prop Plug, you could carefully solder a 4-pin right angle 0.1" header to this area since there are 4 holes mostly filled with solder there.
If you have a USB BOE, you could plug a Spin Stamp into its socket and use the existing on-board USB to serial adapter for data, but not for programming. I suppose you could use the same circuit as the USB-BOE with pins 1-3. I'm just not sure what it is.
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
I guess I don't understand about the referencing of pins 1, 2, and 3 to +3.3V. I was able to use the DB9 connector on the BOE that I was using with the alpha version of the Spin Stamp to connect via a Keyspan USB to serial adapter to my laptop. I thought the output transistor was referenced to the +5V supply on the substrate. I know it's referenced to Sin for the negative supply.
Paul Baker
Paul Baker
