Roaming toward the light...
Im working on my boe-bot, Im learning the chapter 6 that is the one refering the use of the photoresistors... well after write and load the program to make the robot look for the source of light on the room i try it and works fine but the intensity of the source of light need to be to strong, I increase the value on the average factor to increase the sensibility but still is not working...·why this can be happening?·could be the·value on the resistors that i have on the circuit (220 ohms)?
Mr Fus
Panama City Beach, FL
http://microbots.tripod.com.mx
Mr Fus
I just looked at the Robotics text and realized I'm a little ahead of you. The above is discussed starting at Activity #4. When you're just using a resistor divider, you will need a higher resistor to get better sensitivity from the photoresistor. Look at the box on the top of page 199.
Post Edited (Mike Green) : 5/7/2007 4:39:20 AM GMT
Post Edited By Moderator (Chris Savage (Parallax)) : 7/11/2007 12:21:38 AM GMT
D Faust
