Ir detector for BOE-Bot — Parallax Forums
D FaustD Faust Posts: 608
edited 2007-05-08 22:02 in Robotics
Does anybody know whether the IR detector that comes with the BOE-Bot kit is analog ( it outputs different voltages based on ir amount) or digital (it is either on or off).· The help is appreciated.
D Faust
  • Steve JoblinSteve Joblin Posts: 784
    edited 2007-05-07 01:29
    It is digital... the device goes "high" when it senses a 38khz beam of IR light (which is usually the reflected light from an IR LED being driven at 38khz).
  • D FaustD Faust Posts: 608
    edited 2007-05-07 21:27
    Does the frequency of the signal to the detector have to be 38 kHz, because I set mine off with a remote.
    D Faust
    edited 2007-05-07 21:34
    The center frequency of the detector is 38KHz, but it does respond to a wider range of frequencies. You can download the datasheet from Parallax's website and it shows the response curve (www.parallax.com/dl/docs/prod/audiovis/PNA4601M.pdf).
    edited 2007-05-08 00:09
    Thanks, I read a lot of the info for the larger componets, but I didn't think of checking the documentation becuase I figured that nobody would bother to post it. Parallax is pretty good at posting product info, I should probably check there first.
    D Faust
    edited 2007-05-08 12:04
    Most IR remotes 'modulate' their IR output at between 36 Khz to 42 Khz.
    Personally, I haven't found a remote that won't be detected by the 38 Khz IR-Detector, so it shouldn't be a problem.
    edited 2007-05-08 21:10
    Can you send signals to a TV with the boe bot / BASIC Stamp and an IR emitter? Does anyone have any info on how this might work?
    D Faust
    edited 2007-05-08 21:38
    Thanks, that is just what I wanted!
    D Faust
