PINK Netburner suddenly stopped working
Today I unpacked my PINK Netburner board and started playing around with it.
It was working fine and suddenly stopped working. It could be a coincidence, but it stopped working immediately after I tried doing an HTTP_POST (from a Director Shockwave app I was running off the PINK module).
I'm no longer able to connect to the PINK's various built-in htm files, ftp it, or connect to the html file I uploaded to it.
When I go to use the setup utility I can detect the module. I try to set it to use DHCP (by having all the settings be 0). If I search for the module immediately after "setting" it, it shows up with a green icon and displays the IP address I would expect. But search for it again, it shows up with a red icon and says it is DHCP'd at 0.0.0.0.
Any ideas how to fix this? Is there any way to reset the board (the documentation doesn't specify any).
Thanks for any help.
How is the board being powered? How do you have it connected? Are you able to talk to it from the BASIC Stamp Module?
I don't seem to be able to write & read variables from the BASIC stamp board anymore... it was working earlier (once I figured out to change the baud rate on hte PINK's "Serial Data Port Settings" page.
Also, now I'm not being able to detect the PINK module at all via the setup utility. The LEDs on the module's ethernet port are blinking.
Is there a way to reset the PINK module?
I don't know if this is significant, but the LEDs on the PINK's ethernet plug are just blinking. A few moments ago they went solid for a few minutes when I unplugged and replugged the board into the wireless router... but they're back to blinky behavior.
I noticed the documentation on Netburner's SB70 (which PINK is built upon?) said something about the IPSetup not working via a router. But since it had been working earlier, I assume that isn't relevant (also, it isn't clear to me how I'd have both the board & the PC on the same subnet--or whatever--without using a router... but then, I'm not an IT guy so I don't really know).
