V2Xe compass module from PNI...
Over the years, I have done alot of work using the V2X compass module and the BS2, and also the BS2sx.·(Used for maintaining a constant azmuth angle for tracking a satellite signal from a boat with a dish.)
However, the V2X module is now obsolute, and has been replaced with the V2Xe module.· Has anyone played around with the V2Xe and the Stamp?· If so, would you mind sharing your code.· I have a little issue that I cannot quite figure out.
Thank you...Deno
Thank you...Deno
- Stephen
