Parallax Servo Controller -a stand-alone??
Is this controller a stand-alone printed circuit - i.e. can it be programed then disconnected from the computer and attached, with batteries and servos, to a piece of art? Is the disconnected board powered by the batteries as well as the servos?
It needs a power supply for the logic as well as the servos. You can run the whole thing off the servo supply, but you'll need a regulator and some filter capacitors since the PSC requires regulated +5V and servos typically run at 6-7.5V and create a lot of electrical noise in the power supply.
If you only need to control one to four servos, you might be able to do everything with just a Stamp which has its own regulator and is much smaller than a PSC (and can store quite complex sequences and react to external sensors). Another option would be a Propeller Protoboard which is cheaper and much more powerful (if you need it).
