Does anybody have any RF Module suggestions? — Parallax Forums
SteelSteel Posts: 313
edited 2007-05-04 18:06 in General Discussion
I have a SX that I need to talk to about 200' away indoors.
I have to send it 128 bytes every 1mS.
I am currently sending data at 900k.
Has anybody worked with any reliable radio chipsets at this range with this data rate?
Please help.· I am lost on the internets.
    Have a look at xBee-Pro: www.selmaware.com/appbee/home.htm.
    SelmaWare has a variety of adapters and SparkFun has a "breakout board" as well.
    I've used the shorter range xBee between a Mac and both a Propeller and a Stamp.
    Once you configure it, it powers up as a wireless serial channel although there are
    other modes you can use. Since it uses a packet network protocol, all communication
    is error checked internally.
    I just re-looked at your data rate requirement. The xBee isn't quite fast enough.
    How about using WiFi and Telnet?
    Here's one vendor: www.digi.com/products/embeddedsolutions/digiconnectwime.jsp
    You might be able to use a directional gain antenna to improve the range and they're more
    readily available as a mass market product than some special purpose system.
    Post Edited (Mike Green) : 5/4/2007 6:20:01 PM GMT
