BS2 + EB500/EB501 = Err 3
every now and again, my eb500 starts sending error 3 messages. was'nt sure why it was doing this so when it errors i just reset the stamp until it starts working properly again. and after a random amount of time, it stops working, another reason i make it reset every few executions. below is my code. any of you eb500 veterans that can take a look, i woulde appreciate it.
i want to perfect my code before starting to make the hardware smaller.
' {$STAMP BS2}
' {$PBASIC 2.5}
' BLUE TOOTH DEVICES AS ACCESS CONTROL KEYFOBS
' ALLOW ENTRY AND HOUSE\BUSINESS SCENE BY BLUETOOTH ENABLED DEVICES
'---------------------[noparse][[/noparse] Variables ]--------------------------
bErrorCode VAR Byte
Buffer VAR Byte(17) ' bytes buffer
Check VAR Byte
Char VAR Byte ' character to test
tagNum VAR Nib ' from EEPROM table
idx VAR Byte ' byte index
MACidx VAR Byte ' byte index
'---------------------[noparse][[/noparse] Constants ]--------------------------
SerialPort CON 16
Baud CON 84+$4000
'---------------------[noparse][[/noparse] Data Storage ]--------------------------
'Below are the authorized addresses that are allowed entry
DATA "00:17:00:04:1F:21" ' Clark Ober
DATA "00:12:D2:15:94:3D" ' Chris Gagner
DATA "00:18:A4:B2:EF:5F" ' Bryan Quintana
DATA "00:12:D2:CB:2A:1A" ' Kerry Brandon
DATA "00:12:D1:58:FA:87" ' Scott Matson
DATA "00:12:D1:61:86:A1" ' Ben Cope
Setup:
'set connectable off
'SEROUT 1,84,[noparse][[/noparse]"set connectable on",CR]
'SERIN 0,84,[noparse][[/noparse]WAIT("ACK",CR)]
'SEROUT SerialPort,Baud,[noparse][[/noparse]"Set connectable OFF!",CR]
'SEROUT 1,84,[noparse][[/noparse]"set visible on",CR]
'SEROUT SerialPort,Baud,[noparse][[/noparse]"Set visible OFF!",CR]
'set name
'SEROUT 1,84,[noparse][[/noparse]"set name DOORSTOP",CR]
'SEROUT SerialPort,Baud,[noparse][[/noparse]"Set Name to DOORSTOP!",CR]
'set security closed
'SEROUT 1,84,[noparse][[/noparse]"set security closed",CR]
'SEROUT SerialPort,Baud,[noparse][[/noparse]"Set Security CLOSED!",CR]
'set transmit power
SEROUT 1,84,[noparse][[/noparse]"set txpower 1",CR]
'SERIN 0,84,[noparse][[/noparse]WAIT("1",CR)]
SEROUT SerialPort,Baud,[noparse][[/noparse]"Set txpower 1",CR]
'PAUSE 1000
INPUT 9 'make pin that resets BS2 to input so it has no voltage
'FOR Reset = 0 TO 3
'IF Reset = 3 THEN GetOFF
GetVisible:
'get visable id's and send them to the serialport
HIGH 8
SEROUT 1,84,[noparse][[/noparse]"lst visible 5",CR]
'SEROUT serialport,baud,[noparse][[/noparse]"List Visible...",CR]
'SEROUT serialport,baud,[noparse][[/noparse]"ACK",CR]
GetList:
'Buffer eb500 response
SERIN 0,84,[noparse][[/noparse]STR Buffer\17\">"]
'SEROUT serialport,baud,[noparse][[/noparse]"Start data buffer...",CR]
SEROUT SerialPort,Baud,[noparse][[/noparse]STR Buffer,CR]
PAUSE 500
' poppin fresh checks
IF Buffer(0) = "E" THEN ErrorCode 'Watch for Error codes
IF Buffer(0) = 0 THEN GetVisible 'Watch for end of list VIA blank buffer
'loop to check the buffered address against the Authorized list
FOR MACidx = 0 TO 6 '<--- change number to number of Authorized MACs in EEPROM
Check = 0
FOR idx = 0 TO 16 ' scan bytes in tag
READ MACidx * 17 + idx, Char
IF Buffer(idx) = Char THEN Check = Check + 1
SEROUT serialport,baud,[noparse][[/noparse]Char]
NEXT
SEROUT SerialPort, Baud, [noparse][[/noparse]" - Check chars = ", Check,CR]
PAUSE 500
IF Check = 17 THEN AccessGranted
NEXT
'LOW 9
GOTO GetList
AccessGranted:
'SEROUT SerialPort,Baud,[noparse][[/noparse]"Should I let them in?",CR]
LOW 8
HIGH 7
PAUSE 5000
LOW 7
HIGH 8
Check = 0
RETURN
'ConnectToBuffered:
'SEROUT 1,84,[noparse][[/noparse]"con ",STR bBuffer,CR]
'SEROUT serialport,baud,[noparse][[/noparse]"Connecting to ",STR bBuffer,CR]
'WaitForConnection:
'SEROUT serialport,baud,[noparse][[/noparse]"Waiting for Connection...",CR]
' IF IN5=0 THEN WaitForConnection
'SEROUT serialport,baud,[noparse][[/noparse]"Connection Established! HURRAY!",CR]
'Error Handling
ErrorCode:
bErrorCode = Buffer(4)
DEBUG "Error: ",STR bErrorCode,CR
LOW 9
END
