MacBS2 trouble
After installing the MacBs2 program I noticed something odd... after opening the program from the dock there's no debugging console appearing like the one on the right
http://www.muratnkonar.com/otherstuff/macbs2/index.shtml
even when I click on "file>new" there's still no window comming on...
I installed all the latest update for mac osx and the latest tokenizer.
Is there something else I should check or know... like the programming windows only appear when u plug a microcontroller? I'm rather new to this whole basic stamp thing
I'm running on a macbook pro 1.83 ghz core duo
thanks in advance everyone
I just fired up my copy of MacBs2, and ther's a pane at the bottom that's clearly labeled "<Debugger Pane>". I didn't have a keyspan or Stamp attached. I've attached a picture of said window. Are you sure you don't have it shrunk down? The size is drag-able.
Yeah I know that strictly speaking it's not a debugger. I use it to get results of the DEBUG and SEROUT commands . My understanding is that It's one way comunication, so you can't use it for DEBUGIN, by I don't try to, even when I use a PC.
Sorry about that. I was thinking about the usual debugger window with input and output. You're absolutely right. MacBS2 does have the output-only window. My mistake.
Is there any issues known about any program that might affect MacBS2 such as plugins?
thanks in advance
One last thought- What OS are you using? the software is made for the OS10 range of software I'm on 10.4.9
Post Edited (Larry) : 5/4/2007 1:40:26 AM GMT
I'm running os X 10.4.9... seems like the only way I can get Basic stamp to work properly is via parrallel desktop... on the flip side... the arduino program is working fine... go figure
thanks anyway guys
here's my best shot. Read ALL the directions in the [noparse][[/noparse] MacBS2 2.0b17 Install] folder.
It seems there is an issue downloading and unstuffing the tokenizer from Parallax that is needed with the program.
If you started out with an operating system before 10.4, stuffit came with it. If you were online, the tokenizer was downloaded and installed automagically.
More recent systems don't have stuffit, so there is a Zip file you can get from Parallax instead.
Here's the instructions:
That should do it.
cheers
