Gosub limit? — Parallax Forums
Gosub limit?
Naphtali MooreNaphtali Moore Posts: 42
edited 2007-05-03 07:57 in BASIC Stamp
Is there a limit to the number of GOSUB you can call before a return....
EXAMPLE:
[noparse][[/noparse]code]
Function1:
·GOSUB Function2
Return
Function2:
·GOSUB Function3
Return
Function<n>:
·GOSUB Function<n+1>
Return
[noparse][[/noparse]/code]
  • Naphtali MooreNaphtali Moore Posts: 42
    edited 2007-05-03 07:14
    OK, I preformed an experiment with 8 levels of gosub. I was able to get to 8th function but the was an error on the return from the 5th function. Here is the code I used:
    ' {$STAMP BS2sx}
    ' {$PBASIC 2.5}
    DEBUG "Starting Program", CR
    GOSUB function1
    DEBUG "Program ending", CR
    END
    Function1:
    DEBUG "Entered function 1", CR
    GOSUB Function2
    DEBUG " Returned from Function 2", CR
    RETURN
    DEBUG "ERROR between functions", CR
    Function2:
    DEBUG "Entered function 2", CR
    GOSUB Function3
    DEBUG " Returned from Function 3", CR
    RETURN
    Function3:
    DEBUG "Entered function 3", CR
    GOSUB Function4
    DEBUG " Returned from Function 4", CR
    RETURN
    Function4:
    DEBUG "Entered function 4", CR
    GOSUB Function5
    DEBUG " Returned from Function 5", CR
    RETURN
    Function5:
    DEBUG "Entered function 5", CR
    GOSUB Function6
    DEBUG " Returned from Function 6", CR
    RETURN
    Function6:
    DEBUG "Entered function 6", CR
    GOSUB Function7
    DEBUG " Returned from Function 7", CR
    RETURN
    Function7:
    DEBUG "Entered function 7", CR
    GOSUB Function8
    DEBUG " Returned from Function 8", CR
    RETURN
    Function8:
    DEBUG "Entered function 8", CR
    DEBUG " *** END of chain ***", CR
    RETURN
    Here's the output I got:
    Starting Program
    Entered function 1
    Entered function 2
    Entered function 3
    Entered function 4
    Entered function 5
    Entered function 6
    Entered function 7
    Entered function 8
    Starting Program
    (and it starts all over again....)
    edited 2007-05-03 07:21
    OK! The answer is: Yes there is a limit. It appears to be 4. There is a maximum of 4 nested GOSUB statements. BUT I don't know if this is Stamp or MEMORY dependent. I am using a BS2SX and had no other variable declared, RAM and EEPROM were pretty much open. Im guessing the stamp has 4 dedicated bytes for saving GOSUB addresses. This might be different of other stamps.
  • Bruce BatesBruce Bates Posts: 3,045
    Naphtah -
    Feel free to experiment, but if you had looked at the PBASIC Reference Manual, or the PBASIC Help File, you would have found the following:
    quote
    GOSUB Restrictions
    Only a limited number of GOSUBs are allowed per program, and they may be nested only four levels deep. In other words, the subroutine that's the destination of a GOSUB can contain a GOSUB to another subroutine, and so on, to a maximum depth (total number of GOSUBs before the first RETURN) of four. Any deeper, and the program will "forget" its way back to the starting point (the instruction following the very first GOSUB).
    end quote
    This is true for all PBASIC Stamps.
    Bruce Bates
