Basic question, troubleshooting
Hi, I've been playinga around with BS2's wiring accelerometers using the board of education and now I want to assemble a circuit to luanch. Problem one is that the board of education is too big to launch so I'm trying to wire up a bare bones circuit with my own DB9 and the like. I have a BS2e and I followed the schematic for wiring it to the DB9. When I go to test it out, the MacBS2 software (which works fine on the board of education) does not find the BS2e. Well I'm basically stumped at this point. I need some ideas to tell me how to troubleshoot if I have a bad BS2e or a bad connection in the DB9.
Thanks...
Thanks...
2) I don't know how much current the accelerometers draw. If you're using a 9V radio battery, check to make sure it's not run down. They don't have a lot of capacity.
Remember, connect wires will have a dot to indicate they are connected. Not dot means no connection. Take care.
