Bipolar or Unipolar?
Bill Chennault
All--
Can anyone tell if this Jameco NEMA Frame 17 stepper is a bipolar or unipolar stepper? It may be obvious from the Jameco description to someone knowledgeable about these things. There is also a link at the Jameco site to the data sheet.
It looks like both of Parallax's stepper controllers have the current capacity to handle the Jameco stepper. And, the Parallax·BiStep controller will drive two steppers of either type, but with reduced current draw. However, to me it still looks healthy enough to handle a couple of the 400ma Jameco steppers linked to above.
So, which Parallax stepper controller do I need? Either?
Thanks.
--Bill
You are what you write.
Thanks.
--Bill
Thank you.
If you have the opportunity, can you tell me if the fact that it is "two phase" told you or if you "read" the "datasheet", specifically looking at the coil·wiring diagrams?
--Bill
Man, that is one of the most poorly reproduced data sheets I've ever seen for an item somebody was trying to sell.
- Rick
I did base my answer on the 2-phase description. You can also make a fair guess by the number of wires. Usually 4-wire units are Bi-Polar and 5 or 6 wires are Unipolar 4-Phase. Of course you should always verify information before making a purchase. Take care.
I can't tell for sure if it's an "f" coil or an "i" coil winding on the spec sheet. I think it's an 'f' , then I agree with Rick and Chris it's bipolar.
Even if it's an "i" winding, it can still be used in bipolar mode by ignoring the common wires.
So if you want to order the controller and the steppers at the same time, order bipolar.
for future reference, some steppers can be used in either mode
4 wires-- bipolar only
5wires-- unipolar only
6 wires-- either mode- ignore the common wires for Bipolar
8 wires-- either mode- the most flexibility in driving
for the ultimate explanation on steppers, go here
www.cs.uiowa.edu/~jones/step/
Thank you very much.
Larry, the link to the excellent tutorial is much appreciated.
--Bill
