Power supply circuit
Jon Keinath
I am currently designing a device with the Javelin Stamp, that needs to be powered from a 24VDC or AC source.
I have attached a diagram of the circuit I plan on using. Is it a "proper" power supply, or not? Are there any improvements that should be added?
I am using the 12V to supply the Javelin Stamp, the separate 5V to supply an 4x20 LCD and the 5 volt that is connected to the 12V to supply power for other chips (shift registers, timeclock, etc.)
-Jon
-Jon
www.jonkeinath.com
-Jon
-Jon
www.jonkeinath.com
lets see what this does... KA BOOM (note to self do not cross red and black)
Edit - And also I meant to point out that if the input is 24v DC, then you can leave out the bridge rectifier, you only need those diodes if the input is AC
- Rick
Post Edited (RDL2004) : 5/3/2007 2:57:20 AM GMT
I would suggest that you estimate the dissipation of each regulator and add an appropriate heat sink, if needed.
In particular, the LM7812 could have a problem because it has a large voltage drop(~35v-12v=23v) across it, plus it has to handle the
additional current from the downstream LM7805.
DaveG
-Jon
www.jonkeinath.com
- Stephen
