Serout WORD variable ??? — Parallax Forums
fiveslofiveslo Posts: 40
edited 2007-05-02 03:19 in General Discussion
How can I program my SX28 to output a WORD variable serially?· I believe·I have the SERIN side working, since, when from a terminal program, I send a "channel" to sample, I have successfully made the SX display the channel I've sent, since the channel value is 0-11, "byte territory" all works or at least appears to work correctly.· as you can see... I'm still working on my TLC2543 project, and would like to output serially the WORD variable "result", to a BS2p.· I've tried and mostly hacked all examples that I've found on the web but to no avail....· Is there a way to SEROUT what you see in the WATCH directive???· Below is a copy of code I've tried in the TX_BYTE subroutine....
' Device Settings
DEVICE SX28, OSCXT2, TURBO, STACKX, OPTIONX
FREQ 4_000_000
' IO Pins
sclk VAR RC.7 ' clock out from SX/28 to AD2543
sdo VAR RC.6 ' data out from SX/28 to AD2543 sdi
sdi VAR RC.5 ' data in from AD2543 sdo to SX/28
ADcs VAR RC.4 ' AD2543 chip select, active low
Sin VAR RA.1 ' pull-up via 4.7k
Sout VAR RA.0
' Constants
Baud CON "T9600" ' open for single wire
' Variables
serbyte VAR Byte ' serial IO byte
ADch VAR Word ' selects AD external channel 0-10
result VAR Word
temp1 VAR Byte
temp2 VAR Byte
temp3 VAR Byte
tmpW1 VAR Word
' Watch Directives
WATCH result,13,UDEC ' display 12-bit result variable, value in millivolts
PROGRAM Start
' Subroutine Declarations
TX_BYTE SUB 1,2 ' transmit byte to BS2p serial interface
RX_BYTE SUB ' receive byte from BS2p serial interface
' Program Code
Start:
HIGH ADcs ' make CS output
LOW sclk ' make clock 0-1-0
LOW ADcs ' select TLC2543
ADch=$b ' make dummy conversion to intialize converter
GOSUB ADread
Get_Channel_Voltage: ' get data from specified ADC channel
serbyte=RX_BYTE
ADch=serbyte
GOSUB ADread ' get millivolt data from channel specified
BREAK() ' update result variable in watch window
TX_BYTE result
GOTO Get_Channel_Voltage
END
' Subroutine Code
ADread:
LOW ADcs
ADch=ADch<<8
SHIFTOUT sdo,sclk,MSBFIRST,ADch\12 ' mode, left justify ADch
SHIFTIN sdi,sclk,MSBPRE,result_MSB\4 ' get result, 12 bits
SHIFTIN sdi,sclk,MSBPRE,result_LSB
HIGH ADcs ' deselect chip
tmpW1=result**14464 ' convert count to millivolts
result=result+tmpW1
RETURN
RX_BYTE:
SERIN Sin,Baud,temp1 ' receive a byte
RETURN temp1 ' return to caller
TX_BYTE:
temp1=__PARAM1 ' save byte
IF __PARAMCNT=1 THEN ' if no count
temp2=1 ' set to 1
ELSE
temp2=__PARAM2 ' get count
IF temp2=0 THEN ' do not allow 0
temp2=1
ENDIF
ENDIF
DO WHILE temp2>0 ' loop through count
SEROUT Sout,Baud,temp1 ' send the byte
DEC temp2 ' decrement count
LOOP
RETURN
I even tried to output words within "quotation marks" as was shown in the RFID SX/B example, and the literals within quotes displayed correctly, yet when I replaced the literal within quotes with my variable... 'result'... without quotes... the display from the terminal program didn't give me what I saw in the debug window of SX/B...
TX_BYTE:
 Use: LCD_OUT [noparse][[/noparse] aByte | string | label ]
' -- "aByte" is single-byte constant or variable
' -- "string" is an embedded literal string
' -- "label" is DATA statement label for stored z-String
temp1 = __PARAM1 ' byte or string offset
IF __PARAMCNT = 2 THEN ' string specified?
temp2 = __PARAM2 ' yes, save base
DO
READ temp2 + temp1, temp3 ' read a character
IF temp3 = 0 THEN EXIT ' if 0, string complete
SEROUT Sout, Baud, temp3 ' send the byte
INC temp1 ' point to next character
temp2 = temp2 + Z ' update base on overflow
LOOP
ELSE
SEROUT Sout, Baud, temp1 ' send the byte
ENDIF
RETURN
I plan on·"replacing" the terminal with the BS2p,·but since I can't get·this to work with the terminal I'm stuck·and really need some help...Rob
    edited 2007-05-02 02:55
    A word variable must be sent as two bytes. This is not a limitation of SX/B but the way the serial protocol is defined.· Depending on the nature of the system you could send it lowbyte/highbyte or highbyte/lowbyte. Take care.
  • Sparks-R-FunSparks-R-Fun Posts: 388
    Rob,
    As Chris pointed out, you will need to call TX_Byte twice since a byte is expected for serial transmission and you want to transmit the double-byte value that is held in a word variable.
    Something like the following should work:
    TX_BYTE Result__MSB
    TX_BYTE Result__LSB
    The "__MSB" and "__LSB" suffixes are automatic aliases SX/B creates for word variables so that the individual bytes that comprise the variable can be addressed separately. Pretty cool, eh?
    As Chris also noted, you may need to switch the order of the statements if your BS2 is expecting the Least Significant Byte to be sent first.
    Also, depending upon the capabilities of the terminal program you are using, you may not be able to visually recognize the correct values. Your terminal program will likely attempt to display each byte as a character or interpret it as a control code of some kind.
    - Sparks
