Help with long-alinging a byte array in VAR
Is there a way to tell the compiler to long-align a byte array in VAR?
'This is example code... 'Watch address $006C in main memory 'It gets over writen when the assembly runs the wrlong 'This is because buffer[noparse][[/noparse]] is not long-alinged in main memory var long temp byte temp2 byte buffer[noparse][[/noparse]2048] pub main cognew(@StartASM, @Buffer) temp2 := 1 repeat repeat temp from 0 to 2047 buffer[noparse][[/noparse]temp] += temp2 * 2 DAT org 0 StartASM mov timer,cnt add timer,tick mov Buffer_Pointer,par mov Buffer_Pointer_Counter,End_Of_Buffer :loop waitcnt timer,tick wrlong Data,Buffer_Pointer add Buffer_Pointer,#4 djnz Buffer_Pointer_Counter,#:loop jmp StartASM Data long $55555555 tick long 5_000 End_Of_Buffer long 512 timer res 1 Buffer_Pointer res 1 Buffer_Pointer_Counter res 1
Paul Baker
Thank you Paul for you quick response...
I will rearrange my variables.....
