UART setup for communication with FTDI Vinclulum chip
azaccagnino
I am trying to setup communication with a device that has the following specs:
·The standard data format is 8 data bits, 1 start bit, 1 stop bit, and no parity with RTS/CTS hardware handshaking enabled.
·This is my UART setup:
txUart· = new Uart (· Uart.dirTransmit,· ·· // Transimt Uart
························· TX,················ ··········· // Transmit Pin
························· Uart.dontInvert,··· ······ / Dont invert transmit pin
························· RTS,··············· ·········· // Handshake Pin
························· Uart.dontInvert,··· ······ // Don't invert handshake pin
························· Uart.speed9600,···· ···· // Serial Speed· 9600
························· Uart.stop1 );······ ········ // 1 stop bit.
··· rxUart· = new Uart (· Uart.dirTransmit,·· // Receive Uart
························· RX,················ // Receive Pin
························· Uart.dontInvert,··· // Dont invert receive pin
························· CTS,··············· // Handshake Pin
························· Uart.dontInvert,··· // Don't invert handshake pin
························· Uart.speed9600,···· // Serial Speed· 9600
························· Uart.stop1 );······ // 1 stop bit.
I don’t seem to be communicating with the device (FTDI Vinculum chip) is my UART setup O.K.?
Thank you,
Andrea Zaccagnino
Nettuno A.S.G. inc.
Thank you,
Andrea Zaccagnino
Nettuno A.S.G. inc.
In that case TX (output) is paired with CTS (input), RX (input)·is paired with RTS (output).
Be sure to define pins as CPU.pinXX where XX is 0 to 15.
static final int pinTX = CPU.pin0; //transmit output, connect to device RX pin
static final int pinRX = CPU.pin1; //receive input, connect to device TX pin
static final int pinRTS = CPU.pin2; //handshake output, connect to device handshake input pin
static final int pinCTS = CPU.pin3; //handshake input, connect to device handshake output pin
static Uart tx = new Uart(Uart.dirTransmit,pinTX,Uart.dontInvert,pinCTS,Uart.dontInvert,Uart.speed9600,Uart.stop1);
static Uart rx = new Uart(Uart.dirReceive,pinRX,Uart.dontInvert,pinRTS,Uart.dontInvert,Uart.speed9600,Uart.stop1);
If the above does not work, try using Uart.invert
regards peter
static final int pinTX· = CPU.pin4; //transmit output, connect to device RX pin
static final int pinRX· = CPU.pin5; //receive input, connect to device TX pin
························· pinTX,
························· Uart.invert,
························· pinCTS,
························· Uart.stop1);
························· pinRX,
························· pinRTS,
I also have an oscilloscope conneted to pinTX. When I send the following command: tx.sendString("Rx07") nothing happens. The pinTX does not send a signal (the oscilloscope is flat) . If on the other hand I associate the pinCTS with the rx Uart and the pinRTS with the tx Uart I have a signal ont the pinTX. What could cause this?
Thank you for your help.
Give us a link to the datasheet of the·exact ftdi chip you are using.
Tell us which javelin pin you connect to which FTDI pin
and which pins of the FTDI you set·high or low to enter·uart mode.
Schematic diagram if possible.
regards peter
Here are the links of the FTDI chip, of the Firmware and of the schematics:
http://www.vinculum.com/documents/datasheets/DS_VDIP1.pdf
http://www.vinculum.com/documents/fwspecs/DS_VNC1L_FW_VDAP.pdf
http://www.vinculum.com/documents/schematics/VDIP1 Schematic Prints.pdf
I have connected the following pins:
static final int pinTX = CPU.pin4; //transmit output, connect to AD1
static final int pinRX = CPU.pin5; //receive input, connect to AD0
static final int pinRTS = CPU.pin2; //handshake output, connect to device AD3
static final int pinCTS = CPU.pin3; //handshake input, connect to device AD2
AC5 and AC6 are both held high to enter UART mode.
Hopefully this is enough for your help.
Andrea Zaccagnino
If I understand Uart serial comm correctly the microcontroller waits for RTS to go high before sending the transmit data on TX. It looks like RTX never goes high therefore my javelin stamp does not transmit. Is this analysis correct? What could I do to solve this?
Thank you,
Andrea Zaccagnino
javelin TX to ftdi AD1 (RXD)·· correct
javelin RX to ftdi AD0 (TXD)·· correct
javelin RTS to ftdi AD3 (CTS)· correct
javelin CTS to ftdi AD2 (RTS)· correct
Don't forget you need to connect javelin GND to ftdi GND
AC5 and AC6 both high (pullup) to enter uart mode· correct
Your setup should be
static final int pinTX = CPU.pin4; //transmit output, connect to device RX pin
static final int pinRX = CPU.pin5; //receive input, connect to device TX pin
I think you need to create a local connection on the ftdi:
DTR (AD4) to DSR (AD5)
Assuming you have the correct baudrate, the above should work.
In case it doesn't you need to play with the Uart.dontInvert settings
static Uart tx = new Uart(Uart.dirTransmit,pinTX,Uart.invert,pinCTS,Uart.dontInvert,Uart.speed9600,Uart.stop1);
static Uart rx = new Uart(Uart.dirReceive,pinRX,Uart.invert,pinRTS,Uart.dontInvert,Uart.speed9600,Uart.stop1);
if the above does not work, try
static Uart tx = new Uart(Uart.dirTransmit,pinTX,Uart.dontInvert,pinCTS,Uart.invert,Uart.speed9600,Uart.stop1);
static Uart rx = new Uart(Uart.dirReceive,pinRX,Uart.dontInvert,pinRTS,Uart.invert,Uart.speed9600,Uart.stop1);
static Uart tx = new Uart(Uart.dirTransmit,pinTX,Uart.invert,pinCTS,Uart.invert,Uart.speed9600,Uart.stop1);
static Uart rx = new Uart(Uart.dirReceive,pinRX,Uart.invert,pinRTS,Uart.invert,Uart.speed9600,Uart.stop1);
regards peter
Post Edited (Peter Verkaik) : 5/8/2007 1:02:40 PM GMT
Thank you Peter for all your help.
Now please·tell·us your working setup so others that want to use that chip
don't have to work it out all again. Thanks.
regards peter
