Parallax/Google search anomaly
When using the search string: "lcd sx -propeller site[noparse]:http:[/noparse]//forums.parallax.com/forums/default.aspx?f=7", I get zero results.
If I eliminate "-propeller" I get lots of results. Does this imply that I cannot search just 1 particular forum or eliminate a common word from the search? Is there a way to search just 1 forum?
Rick
Post Edited (RickB) : 4/29/2007 10:30:54 PM GMT
Rick
You're only supposed to specify the domain name but you specifying a specific path. Use only forums.parallax.com for the site. Take care.
What is it about "propeller" (or Google search) that causes the search to balk on "not" propeller?
BTW, excluding·"prop", "propel" do work (but probably not in the word-stemming sense since Google says it doesn't do stemming or wildcards), just not excluding "propeller"???
PAR
Rick
Rick
Doing this returned a page of results.
Just in case, here is the address used:-
www.google.com.au/search?hl=en&q=site%3A+forums.parallax.com++lcd+sx+-propeller&btnG=Google+Search&meta=
*Peter*
You’ve found a feature that Dot Net Bulletin Board(Parallax forums) uses that’s throwing off the Google crawls.·
If you look in the upper right hand corner of any forum or topic, you’ll see a Forum Quick Jump drop down menu.· Any of the words used to name a forum topic are in that drop down, and are embedded throughout the site.· So a crawl taking place on the forums will include these words, even though the forum topic doesn’t.
If you look at the source code of the site, and search for propeller or sandbox, you’ll see what I’m talking about(if using Internet Explorer simple right click an area on your screen, and select view source, it’ll bring up a notepad with html on it.
Searches performed with an exclusion of any word used in the forum topics are going to be washed out unfortunately because of this feature.
Jeremie
Could the words in the quick jump menu be turned into graphic objects?
Rick
Great detective work on this one !!
Thanks for pursuing the question.
PAR
