Applied Robotics with SumoBot
Hi -
I purchased the kit with two bots. So far I have assembles and tested the sensors. Then I loaded the sample battle code at the end of the smaller of the two books. One bot works perfectly and the other bot just keeps going in a circle pattern. Not sure what to do to fix the one bot.
They are both running the same code. The servos and sensors seem to be fine on both bots. But when using the sample battle code at end of first book. This only happens to one of the two bots.
kh
kh
