Building a remote infrared thermometer ? — Parallax Forums
pamajemapamajema Posts: 5
edited 2007-04-28 15:40 in BASIC Stamp
hi everybody
I built a thermometer using the LM35 sensor and the LTC1298
tha displays the result with 3 '7-segments leds'·using MAX7129.
Everything works well on the USB breadboard but I would like to know
what king of IR transmittor and receiver to use to make a remote sensor
in a very small box.
Thanks a lot for your help
Jessica
    edited 2007-04-28 15:29
    Do you mean you want to use IR for communications or do you want a non contact IR thermometer?
    - Stephen
  • pamajemapamajema Posts: 5
    edited 2007-04-28 15:32
    hello
    I want to use IR for communication between the USB development board and the other stuff with the LM35,....
    This article www.parallax.com/dl/docs/prod/sic/WebIR-%20v1.1.pdf referenced by P.J.Allen in another topic talks to communicating with a boebot from a tv remote but the communications might give you some ideas.
    - Stephen
