Frequency generator
· What is the best way to generate a frequency from 0 to 4.5khz
and ramp it up over about 20 to 30 seconds, needs to be a linear ramp.
Then run at that frequecy.
I think there has to be an easy way to do this.
Thanks for an hints you can give.
Jim
Jim
One of my very early SPIN files .. needs a little cleaning up but it is close
Play with the M values right down the bottom and even delete one of the case statements totally
It ramps up·. ramps slower...· + runs at a speed forever until reset.
Cheers· Ronald Nollet Australia
{{ This code ramps pulses to pin4
Once ramped up the motor runs forever.
CON
· _clkmode = xtal1 + pll16x
· _xinfreq = 5_000_000
· Pulse_width = 2000······ 'Delay, in clock cycles for on/off time
· Minimum···· = 1500
Var
long··· M
PUB Flashes
· M := 400_000
· dira[noparse][[/noparse]4]~~···················· 'Set I/O Pins to output direction··········································
· dira[noparse][[/noparse]19..23]~~
·· repeat
····· !outa[noparse][[/noparse]4]
····· waitcnt(Pulse_width + cnt )
····· waitcnt(M + cnt)
····· case M
······· 50_000..400_000····· : M := M - 1000·····
······· 3999..49999········· : M := M - 5
······· 50..3999············ : M :=1400 + Minimum
··· I will give this a try this morning and let you know how it worked.
·· My attempt would ramp very slowly a first but as it got faster the change was faster
··· due to changes in the speed caused the changes to happen sooner.
··· Thanks
··· Jim
Tracy Allen
www.emesystems.com
· Jim
··· I noticed there is a CTR.spin in the lib that is a very good place to start learning to use counters.
Thanks for the heads up.
Jim
