Can anyone tell me if Air-Core motors can be attached to the Javelin? — Parallax Forums
FCIProjectFCIProject Posts: 3
edited 2007-04-26 15:30 in General Discussion
Hi
I am investiagting using the Javelin Stamp for a project I am working on. I know Java pretty well so using this for programming hardware will be a good method.
Electronics is a new challenge for me, so please reply in laymans details.
I look forward to someones reply.
Regards
Gary
[noparse][[/noparse]Subject Added by Moderator]
Post Edited By Moderator (Chris Savage (Parallax)) : 4/26/2007 5:47:41 PM GMT
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2007-04-26 15:05
    Gary,
    I googled for Air-Core motors
    and got a list of datasheets.
    http://www.onsemi.com/PowerSolutions/parametrics.do?id=407
    Datasheet of one of the dip versions
    http://www.onsemi.com/pub/Collateral/CS4121-D.PDF
    shows the need of sin and cos signals.
    I think you can use the javelin by using such a chip, with the
    javelin generating the pulsetrain (FreqIn). The datasheets specifies the
    frequency as 0-20kHz.
    regards peter
  • FCIProjectFCIProject Posts: 3
    edited 2007-04-26 15:18
    Hi Peter
    Thanks for looking into that for me.
    As long as it is conceptually possible to hook up an Air-Cire, using a driver chip, to Javelin that is excellent.
    Cheers
    Gary Edwards
    FCIProject
    www.ge-tec.co.uk
    edited 2007-04-26 15:25
    The only bad thing is that you cannot set the frequency in a lineair fashion.
    With PWM, you set the low and high period (F=1/T). One option is to encode
    a frequency in main code, setting a pin low and high in a loop but that may
    be too restrictive.
    An other option is to use DAC, which runs in the background, and apply
    its analogue output, to a separate Voltage-to-Frequency chip (aka VCO).
    That lets you set the frequency in a lineair fashion and then just
    run your application code.
    regards peter
    I will have to talk to my friend, who is an electronics wizard, about that.
    Gary
    Gary Edwards
    FCIProject
    www.ge-tec.co.uk
