I know this is a rather old post but I recently found myself also seeking out an object to run this display driver... The data sheets are really easy to find, but this newbie is nowhere near skilled enough to write a driver for this thing... I did find the website of an individual who has BSX code posted that supposedly would run this display... Currently the links to the code are not working so I sent the individual an email asking him to correct them. Here is his site: http://osmanardali.com/BasicStamp/LCD.htm. Hopefully he will fix the links and we will have something to go on... I realize you have probably moved on from that project by now, but I figured others with this device might find this info useful.
edit : DOH ! Seems an object for the KS0108 exists in the object exchange... (I was searching for the earlier KS0107 version - hopefully they are simular...)
Man you gatta love the community that surrounds Parallax... They make this stuff look easy.
Post Edited (rogersyd) : 2/13/2010 12:52:07 AM GMT
Roger - for reference you can also look at the code I use for a graphical monochrome LCD I sell. The code was written so there is the display driver and the standard graphic.spin routine can be used to draw on the screen.
I would see how this person's code does it·(follow link).
http://www.piclist.com/techref/microchip/language/c/ks0107.htm
Then port as much as you can to Spin and ask questions about specific things when you get stuck.
Good luck,
fish
[noparse][[/noparse]urlhttp://www.brilldea.com/product_LM9033A.html
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
