H Bridge chip
I have a stepper motor that is rated at 1.5 volts and 3 amps.· Any suggetions on what chip I should use for the power switching.· I was looking at the LMD18201T http://www.national.com/pf/LM/LMD18201.html·but when i look at it on digikey ( http://www.digikey.com/scripts/dksearch/dksus.dll?KeywordSearch?Keywords=LMD18201T·) it says it is rated at 55 to 220 volts, and i only plan on using 2 volts maybe 10 during peaks,· will it still work for me?· I am certainly open to other chips, the cheaper the better, I am going to end up needing 3 or 4 for them
Thanks.
Thanks.
