PSC — Parallax Forums
PSC
Tony BoersmaTony Boersma Posts: 41
edited 2007-04-25 17:40 in General Discussion
I received my PSC (and 2 free servos) this morning, and a PIR sensor, I had no idea the PIR was so big (I know it's in the documentation, but still). Now all I have to do is figure out what my project is. I think I have a few other servos, plus I bought 2 over the weekend from a hobby shop here in northern Kentucky.
I also have a bunch of pings, I think I'll build something for my cube for when someone comes and bothers me a death-ray type of weapon (inert) will track in on them and follow them.
Question:
I think the answer is yes, but will the PSC control the HB25? If so the 2 pack of those will be my next purchase.
Thanks Parallax!
Tony
  • JonnyMacJonnyMac Posts: 9,800
    Yes, the HB-25 takes a servo-type signal so it's compatible with the PSC. If you want to use two HB25s you'll need to put them on separate PSC pins. If you connect directly to a Stamp or other micro you can share a pin as you have control over the command pulse timing (something that's fixed in the PSC).
