Parenthases — Parallax Forums
Parenthases
sv806sv806 Posts: 14
edited 2007-04-25 03:36 in BASIC Stamp
a couple codes i found in the help file for pbasic, i was wondering if the ( ) are needed in the first code? and what is bin1 in7, CR do?
Setup:
  INPUT 4
Hold:
  IF (IN4 = 0) THEN Hold                        ' Stay here until P4 is 1
Main:
  INPUT 7                               ' Make P7 an input
  DEBUG "State of P7: ",
        BIN1 IN7, CR
  OUT7 = 0                              ' Write 0 to output latch
  DEBUG "After 0 written to OUT7: ",
        BIN1 IN7, CR
  OUTPUT 7                              ' Make P7 an output
  DEBUG "After P7 changed to output: ",
        BIN1 IN7
  END
    edited 2007-04-25 02:46
    BIN1 IN7, CR is part of the debug statement above it. DEBUG outputs data to the computer on the serial port in this case it prints "State of P7: <binary value of pin7> <carrige return>
    IN7 is the input value of pin7
    - Stephen
  • sv806sv806 Posts: 14
    edited 2007-04-25 03:03
    thank you...now to see if those parenthases are required
  • curious1curious1 Posts: 104
    Syntax and ref. man.· Page 128
    not necessary for pbasic 2.0 and 2.5
    Used within an expression will change the order of evaluation. i.e. math problems.
    RC
