PINK Kit — Parallax Forums
PINK Kit
Pat AlonziPat Alonzi Posts: 27
edited 2007-04-25 21:19 in BASIC Stamp
Hey everyone,
I am interested in ordering the PINK network kit. Does anyone have one up on the web? I'd love to see a website being served by the module. Also, How well would this unit function if I attached it to a wireless network bridge?
-Pat Alonzi
palonzi@ecn.purdue.edu
  • stamptrolstamptrol Posts: 1,731
    edited 2007-04-25 18:51
    Pat,
    I have a PINK online for testing. It has the simplest possible web page running with live update of a counter.
    I'll post the current URL when I get home.
    It really is a super piece of gear and worth learning how to read between the lines of the instructions!
    ·I'm hard-wired to the router at the moment, but I have run successfully with a wireless bridge.
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
  • bshackbshack Posts: 13
    edited 2007-04-25 19:13
    Pat,
    I am having trouble with my PINK netburner card.. I made a post about it here:
    http://forums.parallax.com/forums/default.aspx?f=5&m=187463
    Here is my problem:
    I am having trouble getting my PINK Netburner Ethernet card up and running. I am able to see it using the ip config application and I set it up as DHCP. I am able to visit the card's webserver by going to the ip address. But I am unable to FTP to it for visit the other pages such as VV_Show.htm. I get 404 messages when I try to load all the pages except INDEX.htm. Any ideas of what I have done wrong? Did I miss a config setting? Is there a way to reset it to factory conditions so I can do the setup process again?
    - Bill Shackelford
    http://billshackelford.com
    edited 2007-04-25 20:03
    Pat, Bill and anyone else interested,
    142.167.71.182
    user: sci
    password: katomda
    You can see the html code by clicking on View, Source on your browser.
    Bill, Sounds like the correct proceedure. When you go to FTP://your.units.ip , do you get the drag-and-drop menu system?
    Cheers,
    Tom Sisk
    Tom,
    It is unable to connect via ftp.. I just get standard connection error dialog. If I had a wire out of place from the diagram provided by the kit would that cause this problem?
