Class files
Robot Freak
Is there a .exe file to make .class files of .java files?
Thanks!
Thanks!
You can call jikes.exe (the compiler used by javelin IDE) directly from a commandline (dos box).
regards peter
-Scott
IBM Research Jikes Compiler
(C) Copyright IBM Corp. 1997, 1999.
- Licensed Materials - Program Property of IBM - All Rights Reserved.
use: jikes [noparse][[/noparse]-classpath path][noparse][[/noparse]-d dir][noparse][[/noparse]-debug][noparse][[/noparse]-depend][noparse][[/noparse]-deprecation][noparse][[/noparse]-g][noparse][[/noparse]-nowarn][noparse][[/noparse]-nowrite][noparse][[/noparse]-O][noparse][[/noparse]-verbose][noparse][[/noparse]+1.0][noparse][[/noparse]++][noparse][[/noparse]+B][noparse][[/noparse]+D][noparse][[/noparse]+E][noparse][[/noparse]+F][noparse][[/noparse]+K][noparse][[/noparse]+M][noparse][[/noparse]+P][noparse][[/noparse]+T][noparse][[/noparse]+U][noparse][[/noparse]+Z] file.java...
-classpath path··· use path for CLASSPATH
-d dir············ write class files in directory dir
-debug············ no effect (recognized for compatibility)
-depend··········· recompile all used classes
-deprecation······ report uses of deprecated features
-g················ debug (generate LocalVariableTable)
-nowarn··········· do not issue warning messages
-nowrite·········· do not write any class files
-O················ do not write LineNumberTable
-verbose·········· list files read and written
+1.0·············· recognize only 1.0.2 language
++················ compile in incremental mode
+B················ do not invoke bytecode generator
+D················ report errors immediately in emacs-form without buffering
+E················ list errors in emacs-form
+F················ do full dependence check except for Zip and Jar files
+Kname=TypeKeyWord map name to type keyword
+M················ generate makefile dependencies
+M=filename······· generate makefile dependencies information in filename
+P················ Pedantic compilation - issues lots of warnings
+Td...d··········· set value of tab d...d spaces; each d is a decimal digit
+U················ do full dependence check including Zip and Jar files
+Z················ treat cautions as errors
Version 0.47 (10 Mar 99) by Philippe Charles and David Shields, IBM Research.
Please report problems to shields@watson.ibm.com.
or via browser at http://www.ibm.com/research/jikes
Javelin example that should work (assuming Javelin IDE installed in default directory)
jikes -classpath "c:\program files\parallax inc\javalin stamp ide\lib;c:\program files\parallax inc\javalin stamp ide\projects;" file.java
regards peter
-Scott
"C:\Program Files\Parallax Inc\Javelin Stamp IDE\jikes\jikes.exe" +E -depend -g "C:\Documents and Settings\Jonathan\Desktop\javelin\code\javelin\%*.java" -classpath "C:\Documents and Settings\Jonathan\Desktop\javelin\code\javelin;"
"C:\Documents and Settings\Jonathan\Desktop\javelin\javelin direct\JavelinDirect.exe" JavelinDirect --path "C:\Documents and Settings\Jonathan\Desktop\javelin\code\javelin" --port 8 --listen %*
You will need to change the path but you can get an idea!
