sxvideo revD pal question and remark
I adapted the sxvideo revD pal version to use port B pins (attached) on a sx18.
It runs currently @50MHz.
Is it possible to run this @20MHz and what needs to be changed to make that work?
I have a remark regarding the resistor values used.
Current setup
VsyncPin --[noparse][[/noparse]1000]---+
VoutPin· --[noparse][[/noparse]470]----+····cable······ |
··································· [noparse][[/noparse]75]
···································· V
The output impedance equals 1000//470 = 320 ohm. So there is an impedance mismatch.
Alternative setup
VsyncPin --[noparse][[/noparse]625]----+
VoutPin· --[noparse][[/noparse]268]----+····cable······ |
·················· ·|·············· [noparse][[/noparse]75]
················· [noparse][[/noparse]125]············· |
················· ··|··············· V
················· · V
The output impedance equals 625//268//125 = 75 ohm.
I expect this to give a sharper picture (no reflections) when a long videocable (approx. 10 meters) is used
compared to the current setup. Any comment on this? I have not tried this out yet as I don't have
a long video cable.
regards peter
Current setup
Alternative setup
a long video cable.
regards peter
· I have attached the current version of the firmware (the current version does run at 20MHz).
· Note that you need to dedicate an entire port for the video (it uses shifts to move bits to video).
··You are probably right about the resistor values.
Bean.
"Educate your children to self-control, to the habit of holding passion and prejudice and evil tendencies subject to an upright and reasoning will, and you have done much to abolish misery from their future and crimes from society"
Benjamin Franklin
www.hittconsulting.com
One remark: The routine
GetChar:
· IF sRecvd = 0 THEN GetChar ' Wait until received bit is high
· PUT __PARAM1,sData········ ' Save the received character
· sRecvd=0·················· ' Clear the received bit
· RETURN
is the same as in revD. I had to replace the line
PUT __PARAM1,sData
by
char = sData
to make it work because the calls are GetChar @char, so the return value is not used.
Or the calls must be changed to
char = GetChar
regards peter
To make that happen I had to use a 7x5 font and discard the
special graphic characters (codes 16-31).
The adapted version runs @20MHz. I run it using a sx18, but a sx28 should work as well.
The character patterns are written as binary bytes, which makes
it easy to change the patterns.
regards peter
Post Edited (Peter Verkaik) : 4/26/2007 2:47:10 PM GMT
Did you notice any difference with the different resistor values ?
Are you making a cool new "toy" or what ?
Bean.
Benjamin Franklin
I have not tested that yet. I only have a 3 feet videocable. Maybe
tomorrow I can get a 10 meter SVIDEO cable.
regards peter
Today I used a 10 meters long coaxial cable (75 ohm) with the two-resistor setup.
I didn't notice any difference with the short cable I used before.
To answer your other question: I am designing a new javelin board that incorporates
an sx18. Since I have a few pins left I thought it would be nice to include a video
output.
I noticed your overlay board uses a LM1881 to detect the horizontal sync.
Have you seen this page:
http://www.sxlist.com/techref/ubicom/lib/io/dev/video/hsync-ng.htm
If you have, and rejected that approach (or perhaps tried to follow it up)
could you tell if it is feasible? I rather not spent time on it if you already
tried it with no success.
regards peter
· Wow! sounds like a cool project.
· Did you develope the Javelin ?
· I tried using the comparitor, but it was really touchy.
· It wasn't that exact circuit, but something similar.
· I decided it was more trouble than it was worth and just put the LM1881 on the board.
· The new overlay board uses the EL1883 because it can run from 3.3V.
Bean.
Benjamin Franklin
Post Edited (Bean (Hitt Consulting)) : 4/26/2007 3:44:16 PM GMT
I got a LM1881 and succeeded in generating overlay with a SX18/28 @20MHz, including sound.
The attachment runs as is on my PAL tv. Could someone·test it for NTSC (in theory just
setting a jumper) and let me know the results?
I managed to put the special graphic symbols (codes 16-31) back in. I changed these
symbols to support horizontal and vertical bargraphs as seen on many tv's.
I added a watchdog function (to reset my javelin in case it hangs).
For the sx28, port C is used for 8 extra output pins.
I had to remove the plot functions that were available in·the sources this adaptation
is based on. There still is the cursorXY command and the DOT graphics so you can
still plot lines. Calculation must be done externally.
Next step is to try the internal comparator as sync separator.
regards peter
Post Edited (Peter Verkaik) : 5/5/2007 7:11:37 PM GMT
Since chardots gets overwritten prior to outputting bit2, this bit got corrupted (routine videoline).
For this reason I rightshifted the patterns by 2 bits and save bit0 in the carry
prior to overwriting chardots.
The error did not show until some graphic symbol was used, because for most
character patterns bit2 (now bit0) is 0.
I also noted a thing about constants
HSYNC_OVL CON 3
HSYNC_EXPIRED CON HSYNC_OVL+1
generates more code than
HSYNC_OVL CON 3
HSYNC_EXPIRED CON 4 'HSYNC_OVL+1
so I changed that for the better.
I also added the character as comment in the pattern tables.
regards peter
with three programs.
The 6x16 is the same as my previous uploaded program with a small bugfix:
the invert mask in routine VideoLine had to be reset before each character,
not just at the start of a line.
To free up program space, I encoded the 8x6 font using all 12 bits in a code word.
The tradeoff is that than only 13 chars per line can be displayed. There is
however 75% of program space in code page 2 available (approx. 380 words).
To get more text than 6x13 I redefined the display memory use.
Instead of a rambank array holding a line of text, I defined it to hold
2 columns of text, so to get a 8x12 display. And there still is the same
amount of program space available as for 6x13.
I defined some display properties as constants.
You set ROWS and COLUMNS and calculate the values of the other constants.
By setting ROWS and COLUMNS to a value < maximum, you can free up some
ram space which you can then use by declaring aliases.
regards peter
I used Bean's idea of using a single port register as shiftregister.
However, simply rotating RB only works if all pins are outputs.
I have overcome this by using
RL CharDots
RR RB
The conditions are therefore:
VideoOutPin must be either at port.7 or port.0 so the bit can be outputted in 2 cycles.
This version has also 6 button input support, programmable watchdog output
and a bidirectional serial channel (1200 baud).
Code page 2 is only used by 18 words, so plenty of space left
for additional graphic characters or some other functions.
Screen resolution is 6 lines by 16 characters.
The code as is works for PAL. To make it work for NTSC change VidSize (not tested).
I attached the SRC also because the SXB must be compiled with compiler 1.51.03
regards peter
· I love it !!!
· Quite a bit of function with a humble SX18.
· Good idea using the two rotates. Frees up 7 pins.
Bean.
Uhhhm, that was on fire when I got here...
www.iElectronicDesigns.com
I added the ability to let lines blink in any combination. Blinking lines all
blink simultaneously and at a compiled rate (0.5sec on, 0.5sec off).
This is·great for·displaying alert warnings.
Also added the ability to set a doubleheight font (display appears as 3x16).
This means only lines 1,3,5 are displayed but you still write display contents
on a 6x16 display.
A·nice feature when using doubleheight font is updating offscreen lines and then
swapping screens to make updates appear instantly.
I added a detailed command description.
The upper half of codepage 2 is still available, together with 1 free rambyte and 1 free rambit.
Another feature (not implemented yet) using doubleheight font is to treat the
display as 3x32 and having left and right shift or rotate (for walking text).
One minor issue:
When changing from normal font to doubleheight font, my TV sometimes fails to synchronize
on the vertical sync. From doubleheight font back to normal font always works.
If anyone can spot why this is, that would be a great help.
regards peter
Post Edited (Peter Verkaik) : 6/21/2008 10:41:01 AM GMT
I implemented doubleheight font, invert, blink/flash and walk, per line.
Blinking is line on/off every 0.5sec
Flashing is line inverting every 0.5sec
You can select at runtime either blink·or flash but not both.
Walk is performed using two consecutive lines.
You can also select which lines should be hidden.
See the commands 11,12,14 and 15.
See also command 6 for all possible effect functions.
Also attached is a pdf with possible output screens.
The last screen shows a doublewidth doubleheight font can be used
for a single image or text encoded in the 16 graphic symbols. This is
established by writing characters $10-$1F into a single line.
regards peter
It looks like the __RAM variable declarations aren't what they should be. That is causing the warnings.
I'll look into it...
Bean.
I know that for SX/B beta the ram addresses $FD-$FF need to be changed to $F5-$F7.
However, that does not resolve the warnings.
regards peter
VidSizeVar······ EQU· (__RAM+($F0 & $F0) + $F0) | $10
This yields $1F0
So it must be
VidSizeVar······ EQU· ((__RAM+($F0 & $F0) + $F0) & $FF)·| $10
VidSizeVar······ EQU· ((__RAM+($F0 & $F0) + $F0)·| $10) & $FF
regards peter
Peter I meant to post the above is in the Beta forum...
But anyway, the problem is that the __RAM array should NOT do the "span bank" calculation. It should just use the value as it.
I have fixed it, I will post a new version shortly (a couple minutes).
Bean.
- Sparks
satisfactory results. The LM1881N chip does a great job
and for only video output (no overlay) you can simply
leave that chip out.
My latest board has an SX18 setup with LM1881.
Works great.
regards peter
I added a DS2401 (Silicon Serial Number chip) to the Serial Input/Output line.
The program can be used with either SXB1.51.03 or the SXB2.00.27 (the _SXB2 file).
The SXB2 file has an array DummyBytes located just under PROGRAM Start
to move down the remaining code. These bytes are not available in the SXB1.51.03 file.
(SXB2 has shorter PROGRAM code).
As far as I know this is the first osd program that compiles with SXB2.
regards peter
Post Edited (Peter Verkaik) : 7/4/2009 1:48:55 PM GMT
