Question regarding Hydra Sound Driver
Oldbitcollector (Jeff)
I'm looking at the idea of using the SD code to read/send data to the PCM sound driver that comes with the Hydra book/Cd 'NS_sound_drv_050_22khz_16bit' The idea is to read the BYTE data from a file on the flash, streaming it into the PCM driver allowing "almost" unlimited file size and feeding it byte by byte into the driver.
Question: What is the format of the converted data from XGSBMP? Does a single byte contain enough information about a single tone to allow the PCM driver to generate the frequency/duration of a single tone?
(Yes, I know that my samples will be 1000x larger than the games.... [noparse]:)[/noparse] )
Oldbitcollector
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
Oldbitcollector
Oldbitcollector
Andre'
