PING ULTRASONIC SENSOR problem — Parallax Forums
TommyGunn_69TommyGunn_69 Posts: 2
edited 2007-04-24 15:34 in General Discussion
I'm using the PING sensor w/o the stamp controller. I wrote my own program using a minidragon microcontroller. 5v is being sent out to the PING, but only 300mV is seen·coming back·using an O'scope. What am I doing wrong?
    edited 2007-04-24 02:50
    There's a pullup in the PING and a small protective series resistor. The 300mV depends on the circuitry you're using to connect to it and on what your microcontroller is doing. We can advise you on the correctness of your circuitry, but so much depends on your microcontroller and we really can't offer any specific advice on a non-Parallax controller.
  • TommyGunn_69TommyGunn_69 Posts: 2
    edited 2007-04-24 03:41
    Thanks, Mike! We put a resistor in series with the sensor and micro controller and are getting 3.5V now.
    edited 2007-04-24 15:15
    This thread is being moved from the BASIC Stamp Forum to the Sandbox Forum.
  • JonnyMacJonnyMac Posts: 9,798
    Ping uses just one pin for I/O, so immediately following the pinging of the unit with a pulse, you need to make that I/O pin an input. If it's being held low then the return signal from the Ping will not be seen.
