program parallax GPS module with PIC
We brought a parallax GPS module , in our graduation project we tend to connect the GPS , to 16F877A then display the results on LCD . we have a problem in programe the PIC in microbasic PIC language , we tray to translate the code supported at the web and we fail .please send us aprogram in microbasic or any other PIC language ,
please help us as soon as possible .
![cry.gif](http://forums.parallax.com/images/smilies/cry.gif)
We cannot help you with the PIC programming. You will have to find what resources you can from any Microchip or other PIC support forums.
Can you display text on the LCD ? If no, that is your first task.
Can you receive serial data ? If no, that is your second task.
After you have done both of those, it's just a matter of receiving the serial data from the GPS and writing the important characters to the LCD.
Good luck,
Bean.
"Educate your children to self-control, to the habit of holding passion and prejudice and evil tendencies subject to an upright and reasoning will, and you have done much to abolish misery from their future and crimes from society"
Benjamin Franklin
www.hittconsulting.com
For the first poster, let us all understand your request, you come to the parallax site looking for someone to do your final college project for you in PicBasic, is that correct ?
If you start slowly with a stamp and get that working then translation of your code to any one of the pics should be a breeze.
If you check some of the PicBasic forums then you should find enough info to get started.
Good luck with your project.
If you ever enter the engineering world and expect others to do your work then your going to need all the luck you can get.
