Reseting problem, when opening serial port on PC.
Is it possible to connect pin ATM (Pin 3 of BS2) through a switch to the ground, so that when the switch is off I can program and when the switch is on I can get the PC and BS2 communicating. (i.e. is it possible to drain away any logical high from ATN to stop reset)
http://forums.parallax.com/showthread.php?p=646765
