Boe-Bot Digital Encoder ......
Just came across Boe-Bot Digital Encoder Kit, and after going through the documentation I thought of working on it. But I have a small confusion are those sensors similar to that of QTI (Low proximity) . Is it possible to work with QTI Sensors also with slight modification in fixing them????
It really boils down to focal point. If you have big enough wheels and perhaps a white/black disc mounted on the back it may work. Using the standard wheels I’m not sure it would. You may have to simply experiment. Take care.
One significant difference is that the BOE-Bot Digital Encoder Kit uses modulated IR sensing, which makes it more reliable under ambient light variations.
