need help...voice recognition for basic stamp
Hello,
······ well i am working on another biped robot now & i'm looking for help here on a voice recognition for basic stamp? does anyone know where i can get a plug & play board that i can connect to a basic stamp board? or the parts i will need to build a board my self & where i can get what i need to do this? if anyway can give me some help here that would be great.
······· this is my 3rd biped robot i am build & i want to add even more function to this one. i just got the roboeye vision system, the emic voice board,atom bot board,ssc-32 servo control,basic atom pro 28 pin module,ir proximity detector sensor,on-board battery checker,serial lcd module & 32 high torque servos. i want to add a voice recognition to the robot so it can follow voice commands. the robot stands just under 3 feet tall.i made the shell of the bot out of fiberglass in a form of a female being alot of the bots out there look more like male bots.also to help the person the bot is around to feel abit more comfortable.
if anyone can point me in the direction to get the voice recognition·system this would be a big help. once i get the bot done i will post some pix of it.
i am designing the robot help help people in assisted living, to pick up phone & hand it to the person, get them a drink, pick up things they may drop & get the mail. just the basic stuff right now that may be hard for some people that has a disability & may not be able to do it for them self. this is what i have planed for the robot. it's name is ( a.l.i.a.)·assisted . living . intelligent . android .
thanks to all for any help i can get.
Charlie
Charlie
I did some searching and the only item I could find was from your same post on lynxmotion forum. the VR STamp
http://www.sensoryinc.com/html/products/vrstamp.html
if you train the program many times, (even train it on noisy enviroment) I was about 82% accurate.
the trick, is·training the same comand, over and over;·and in different·parts of the day. The human voice goes though changes during the day, specialy in the mornings.
P.s.· I am building the arms for your viped, lets get it done...
http://forums.parallax.com/showthread.php?p=637017
Fernando Gomez
revinc.us
gomez-rivera.com
Never compare yourself with anyone else, there will always be someone bigger·or·smaller·than you.
Post Edited (willy1067) : 4/25/2007 4:19:04 AM GMT
There are several speech to text programs. ViaVoice is one that still exists for the PC and has been improved over the years. I use MacSpeech, obviously for the Macintosh, which also has the ability to control various programs. It comes with script packs complete with the tools to take specific phrases and use Apple's AppleScript to send menu selection and other commands to most common programs. If you had a Mac, you could make your own script pack with specific phrases that would cause commands to be sent to a Stamp or other processor via Bluetooth or an xBee serial channel.
You have to speak slowly and clearly, but you can use continuous speech (you don't have to separate the words). You do have to train it for a given speaker by reading some sample text. The main problem is that there are still errors and you'd have to design the phrases so they are fairly unambiguous. You do need a fast, large memory PC or Mac at the very least. People have made standalone speech recognition systems, but they have very small vocabularies (maybe 12-15 words), they require discrete words, and they make lots of errors.
i could say "Robot, Dance." and he would!
but my favorite tweak was a party popper stuffed with alluminum foil bits, mounted in his back with the string wrapped around a servo. when i would say "Robot, Play dead!" he would pop and make noises and shutter to a halt. it was quite impressive! take a look here at the specs and check it out
http://www.sensoryinc.com/html/support/docs/80-0179-F.pdf
it's simple and doesnt require lots of processor or battery power.
Clark
Problems are the "roads" of life,
solutions are only "onramps" to the next problem
············································· "Brad Smith"
http://www.semiconductorstore.com/pages/asp/item.asp?ItemNumber=60-0235
The dev kit seems a little pricey at $350.
http://www.semiconductorstore.com/pages/asp/item.asp?ItemNumber=66-0110
At $130, this Easy-VRStamp board (cost includes VR Stamp) seems a lot better.
http://www.mikroe.com/en/tools/easyvrstamp/
Do you have the board?
Go with the $350 dev kit for my money value!
I have used the Sensory VR Stamp on a Voice Recognition Dalek and it works great. I have put a video of it on Youtube: http://uk.youtube.com/watch?v=X7kygMHrYq8
Just discovered the Propeller, what an amazing chip, will be using it in the new automonous half size Dalek that I am currently building.
Toymaker
To see Product Innovation - visit our website at www.conceptioneering.co.uk
