DS1620. Displaying the Floating Point with BS2 — Parallax Forums
C.MoherC.Moher Posts: 35
edited 2007-04-20 01:51 in BASIC Stamp
I am using the debug command to display a binary word from a DS1620 converted into·a decimal format. Displays temperature fine but truncates the number, hacking off the tenths decimal. The DS1620 is capable of displaying to a +/-·0.5 C·resolution.·I'd like to see that displayed also. How the DS1620 works is that it sends the number X 2 to the stamp. For example if the temperature read is 22.5 degrees C, it sends the number 45 out (in binary , lsb first) to the stamp. So if you are happy with just an integer measurement, you divide the number by 2 and display it via the debug command. Eg:
degC = x / 2
DEBUG ? degC
Again you get just the integer part...in the above example 22 degrees C...How do I get the decimal part ? Thanks in advance for your help.
  • Robert KubichekRobert Kubichek Posts: 343
    edited 2007-04-20 00:56
    Would multiplying by 10 to shift the decimal, then divide by 2, and just shifting the decimal back work?
    bob
    edited 2007-04-20 01:00
    degC = x * 5   ' this is in units of 0.1 degC, but resolution of 0.5 degC,
                         ' e.g. x=45 --> degC=225
                         ' and  ...,210, 215, 220, 225,... units of 0.5 degC
    DEBUG degC/10, ".", DEC1 degC   ' displays with tenths, e.g. 21.0, 21.5, 22.0, 22.5 etc.
    Tracy Allen
    www.emesystems.com
  • C.MoherC.Moher Posts: 35
    edited 2007-04-20 01:01
    Not sure what you mean by "just shifting the decimal back" ....how ?? Dividing by 10 again ?? I'm not sure, I can try it but what I have gathered from the research I have done, its not an easy task apparently so I don't think something that simple will do it. I'll give it a try though.
    edited 2007-04-20 01:12
    Nope sorry Tracy. That's giving a square.0 repeatedly. Here's what my code looks like now with that in it:
    x VAR Byte ' General purpose variable, Byte.
    degC VAR Byte ' Variable to hold degrees Celsius.
    ' Note: DS1620 has been preprogrammed for mode 2.
    OUTS=%0000000000000000 ' Define the initial state of all pins,
    'FEDCBA9876543210
    DIRS=%1111111111111111 ' as low outputs.
    FREQOUT 0, 1000, 2000 ' Beep to signal that it is running.
    HIGH 13 ' Select the DS1620.
    SHIFTOUT 15, 14, LSBFIRST, [noparse][[/noparse]238] ' Send the "start conversions" command.
    LOW 13 ' Do the command.
    DO ' Going to display once per second.
    SHIFTOUT 15, 14, LSBFIRST, [noparse][[/noparse]170] ' Send the "get data" command.
    SHIFTIN 15, 14, LSBPRE, [noparse][[/noparse]x] ' Get the data.
    LOW 13 ' End the command.
    PAUSE 1000 ' 1 second pause.
    LOOP ' Read & display temperature again.
    ye haw... Tracy your code works fine but you were missing the "DEC' in front of the first degC....should be:
    DEBUG DEC degC/10, ".", DEC1 degC
    Thanks for your help. I'll spend the rest of the week answering the ? "but why"
