Sumobot
Hello,
Can a Basic Stamp run two programs at the same time?
For example: I want to send always·an infrared signal of 36 kHz. And I want my sumobot to follow a line,... at the same time. Can he do that?
Oh, wait, that "always send" means continuous? Then you'll need a properly set up 555 timer chip, which you 'enable' with a BS2 pin.
A BS2 is a single-tasking processor. It can 'hold' signals high or low, but it won't continuously generate a signal. Why continuous, anyway?
Don’t you have to send a signal all the time, so that your opponent can see you all the time?
