Buzzer/555 chip
I'm trying to connect a buzzer to my collision avoidance system that will beep when the car is within certain ranges from an object. I'm sending a PWM signal to the buzzer through a 555 chip but I'm getting weird results. I know this is probably more a 555 issue than a basic stamp one but maybe someone can help. The datasheet (www.national.com/pf/LM/LM555.html) shows many different circuits I can build but I have no idea which one will help the most. I only need two different frequencies and they need to be loud enough to be heard over the motors. Thanks.
Update -- A "buzzer" will buzz on its own, but a "piezo speaker" requires a tone/frequency source.
If it doesn't buzz, hook it up one lead to P0, the other to the -ve rail and use this code:
FREQOUT 0, 2000, 3800
If it buzzes now, it begs the question as to why you are using a 555 timer to begin with when the Stamp can handle this far better.
