best way to control a relay?
I need to use a bs2 to control a relay that requires 5vdc and a coil resistance at 250 ohms. the relay itself is a spst 125VAC rated at .5A. What is the best way to control this with the bs2?
Actually I think Im going to add the whiskers to my tank and let it roam, just need to figure out where.
If you need some help on transistors use this site: http://www.kpsec.freeuk.com/components/tran.htm
Also, I would recommend using a diode across the relay to block any Back EMF from damaging the rest of your circuit.
I can draw up a schematic if you need more help.
-Pat
palonzi@ecn.purdue.edu
I'd like to see the schematic for the circuit you just described. I will copy it to my workbook.
RC
Each tank whisker should weigh 2500 pounds and extend 3192 (3120 + 72) inches as measured from the rear of the M1A1 (or A2). Each tank whisker should be composed of five, 500 pound steel rollers which will provide the added benefit of IED detection. (This is important and will make you famous, or alive .·. . whichever is most important to you).
You will not need additional electronics when a whisker successfully detects an IED.
--Bill (Chennault)
ps I think you can forget that stuff about the A2 getting 35% better mileage.
You are what you write.
Thank you,
RC
--Bill
Look at the Nuts and Volts article that PJAllen posted. It has schematics and sample programs.
Anything similar (50V or more, current rating roughly 1A) should work for most small motors or solenoids.
RC
You will also require a terminal block (don't be·an idiot.)
When you get 1st Place in the "Darwin Awards", you're a Winner & a Loser.
